gawald 30 #1 Posted January 27, 2017 I seldom recommend any tools but am doing so to help out fellow WH owners. I have always struggled to replace tires on riding lawnmowers and garden tractors with the most trouble with smaller tires. Just could not get good leverage on them. I bought a Harbor Freight mini tire changer tool for $30 with a coupon and have used it several times with very good results. It works on the same principle as the large machines at tire shops but is small and manual. I clamp the post is my vise (comes with a bolt down mount which I don't use), mount the tire per instructions and dismount tires and mount them with greatly reduced effort. I have use this tool on up to 8 inch rims so far with good results. I feel I got my $30 worth when changing tires on my Snapper riding mower with 4" diameter rims. The tires were old and brittle but the changer peeled them off with no difficulty. I normally don't buy Harbor Freight tools but tried this one out of desperation and it came through. Has anyone else used this tool? I suspect that the tool may not work as well with larger diameter rims but it is supposed to range up to 12" rims. 7 Share this post Link to post Share on other sites
Kurt-NEPA 756 #2 Posted January 27, 2017 I also gave the HF mini changer a try. Worked just fine on my 8" rims. It helped with 12" rims, but I clearly need a larger changer. In any case I was able to change 4 tires on 8" rims and 4 tires on 12" rim. Well worth the price tag. And it was so nice not to have the old, cracked, and hard tires on my 520H's last summer. 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #3 Posted January 27, 2017 This is the 8" tire bead breaker I fabbed up last summer (should have made it adjustable for more diameters), and thanks for your thoughts on the HF tool,Jeff. 5 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted January 27, 2017 I bought this from GREG SMITH EQUIPMENT @ Indianapolis Indiana. It was a little more expensive than the Harbor Freight model, buy well worth it to me. I couldn't get the bead broke on 2 old ag tread 6 X 12 tires by hand. I beat and beat on them and never did get them broke down. 5 minutes on the changer, and I had both broke down and rubber off the steel! 10 Share this post Link to post Share on other sites
Fun Engineer 863 #5 Posted January 28, 2017 How much is "a little more" KC9KAS? 1 Share this post Link to post Share on other sites
ACman 7,741 #6 Posted January 28, 2017 @KC9KAS , and can you post some pics of the bars (tools) that come with it please . Share this post Link to post Share on other sites
AMC RULES 37,259 #7 Posted January 28, 2017 http://www.gregsmithequipment.com/Heavy-Duty-Manual-Tire-Changer 1 Share this post Link to post Share on other sites
Zeek 2,299 #8 Posted March 9, 2017 (edited) On 1/27/2017 at 0:35 PM, gawald said: I seldom recommend any tools but am doing so to help out fellow WH owners. I have always struggled to replace tires on riding lawnmowers and garden tractors with the most trouble with smaller tires. Just could not get good leverage on them. I bought a Harbor Freight mini tire changer tool for $30 with a coupon and have used it several times with very good results. It works on the same principle as the large machines at tire shops but is small and manual. I clamp the post is my vise (comes with a bolt down mount which I don't use), mount the tire per instructions and dismount tires and mount them with greatly reduced effort. I have use this tool on up to 8 inch rims so far with good results. I feel I got my $30 worth when changing tires on my Snapper riding mower with 4" diameter rims. The tires were old and brittle but the changer peeled them off with no difficulty. I normally don't buy Harbor Freight tools but tried this one out of desperation and it came through. Has anyone else used this tool? I suspect that the tool may not work as well with larger diameter rims but it is supposed to range up to 12" rims. I have used this one Mini Tire Changer Eval , but it takes a little oomph to operate. Edited March 9, 2017 by Zeek Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #9 Posted March 12, 2017 I had the small model HF tire changer that@Zeek evaluated but the dang thing broke after a few years. Last year I purchased the larger HF model and it works great. I did some trading with a fellow member to replace the rear worn out tires on my 416-8 for a nice set of turf tires. I think the tires on the 1988 416-8 were original . Broke the beads without any problems , should have worn rubber boots for the gallon of sealer or crud that was in each old tire. Put the new turf tires with tubes without any problem. 1 Share this post Link to post Share on other sites
