thejangler
657 vs 857 vs 1057? differences, engine suggestions?
thejangler
Few questions, I have a 1967 wheel horse 657 and would like a little more power for plowing and such
Is the only difference between 657 and 857 and 1057 engine size? frame the same? could i find a bigger engine to put in it without fitment issues? suggestions?
Retired Wrencher
thejangler  :WRS:  as for the 657 frame I believe you can put in a 8hp kholer in it Good power there. Not to sure about a 10 or a 12.  I think if you go larger you run into different belts and pulleys. Not much difference between the 6 and 8. The 8`s you can do a lot with them. I have an 8 hp do plowing with it Have a 10c.u. dump cart I fill it with dirt- rocks -wood -tow up hill with it. the thing I like it is a small frame get in to tight spaces with it. Enjoy it what ever you decide.
Edited by T1257 RETIRED WRENCHER.
953 nut
:WRS:     I am not as well versed as some other members when it comes the the subtle differences between long and short frame :wh: in 1967, but I think the 657 and 857 were both short frames and the 1057 and 1257 were long frames. I have attached the manuals for you to look at and hope you can find what you need there.
:text-coolphotos:            Also, you may want to read this over and adjust your plow angle.
stevebo
I have an 857 and have a 10hp Kohler out of a 1054 sitting on the shelf. I too am wondering if that motor will fit under the hood without modifications. Looking forward to hearing from those of you who have done this swap.
Racinbob
:WRS:
Good info from both Richard and Gary. I don't think a 10+ Kohler will fit under the hood of the short frame 657 or 857. Maybe a Tecky will but I don't know. I'm with Steve and would like to hear if anybody has tried to fit the bigger block in a short wheelbase. I'm thinking a no-go without cobbling the hood. :think:
Achto
This post shows an 875 that was fitted with a 12hp Kohler.
  • Like 4
ACman
Welcome to. :rs:  :woohoo:
:text-yeahthat: ...my 1075 rat barn find is my favorite tractor of the bunch !
Big block shortframe square hoods rule :music-rockout:...I think @squonk would agree .
Edited by ACman
slammer302
Glad to see another member from MO. I like the 8hp kohler big enough to get the job done but still small enough to make it interesting.
Racinbob
Interesting. I thought those were long frames. I see the 875 and 1075 use different belt guards to compensate for the difference in shaft height. Unlike the 70's b/c series where the 8hp sat on a riser plate making the shaft the same height as the bigger blocks. Interesting stuff. OK, who's got a 16hp mounted on a short frame? :)
squonk
:)   7AvjsXz.gif
Texas Todd
What is the lever protruding from the belt guard? Only thing I can think of is the hydro release so you can push it. Couldn't find it in the schematic though. Thanks.
Edited by Texas Todd
Sarge
Up to '66 , most hydro models had that lower lever to engage the hydro belt drive and parking brake setup . It all changed in '67 to the lever mounted on the right side at the top of the trans tunnel .
Sarge
refracman
I believe to install a 10 hp you'll need a engine with the short oil pan and the correct belt guard which are specific to the 10 hp short frame tractors
damon91
I have both a 1067 and a commando 8 (which is 1 year newer than the 857 but the same machine) The frame is deffinatly longer on the 1067 and the hood is longer and taller. A kohler 10hp is massive compared to an 8hp. I think It would take an extensive amount of modification to fit a 10hp in a 857.
Edited by damon91
  • Confused 1
857 horse
857......of course,,,,,,,,,,,,more power.????    try  on an 867........or 8 speed your 857........just a thought.....
thejangler
AWESOME, that is really helpful to have the comparison here.  seems like a really big difference in the 8hp and 10hp like you said, thanks again,  merry xmas yall!!
  • Similar Content
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
