Red520
1995 520H
Red520
On ‎9‎/‎21‎/‎2016 at 5:06 PM, gwest_ca said:
A good diagram for the gauges
Garry
Thank you for the Diagrams, they are very much appreciated.
I would order the cam plate along with the follower, as the cam plate usually has worn pretty loose once the follower has flat spots. I like RCPW.com as they are often the cheapest, but there are several places you can go.
I do know that it is supposed to have three fuses, 30, 20, and a 15 maybe? I forget what they are all for so I will let someone else follow up with that.
Thanks for the info. I just ordered the parts including a brake pad for the clutch assembly. I noticed it was almost down to the rivets. The diagram was hard to read but it looked like it calls for a .012 gap setting on that brake pad? Also the third fuse in the diagram shows it connecting to the light switch but I don't see a light switch.
gwest_ca
The operator manual shows the light switch on the left side of the panel that contains all the idiot lights. I have to go by it because I don't have a 520.
To set the pto brake I slip a business card between the pto and the friction material. Apply the pto and tighten the bolts up while holding the brake pad and card tight to the pto. Remove the card.
Garry
Red520
Well, the working gauges and lights were short lived. They worked when I had the tractor running to adjust the tranny drift but when I moved it out of the shed the fuse blew again. I put another one in later and it blew as soon as I started it???? Must be a short somewhere. I ordered the new cam and plate for the hydro tranny to get that issue repaired. I will have to look for the short later when I have time to do so.
Red520
On ‎9‎/‎21‎/‎2016 at 9:36 AM, Red520 said:
I just purchased my first wheel horse tractor. It is a 1995 520H serial #5901574 and I have a few questions to ask. When I received the tractor the idler pulley on the main drive belt was shot so I replaced it. I notice that the drive belt is still doing a lot of jumping and may be stretched. The parts diagram shows the belt but the diagram doesn't seem to be the same as my model. It lists the drive belt as 5/8" x 83". Can anyone tell me if this is correct?  Also the hydro transmission seems to be slightly engaged when in neutral and it will move forward when parked. If I put the brake on it sounds like the transmission is trying to move. Any adjustment for this? I am using this to mow about 3 acres of grass that has a lot of obstacles and I am wonder if the hydro tranny will take a lot of forward and reverse motion? I did tighten the bolt a little on the tranny shift linkage to stop the shift lever from dropping down when it was in motion.
ericj
I've had good luck squeezing the rivet on the throttle linkage with a pair of vise grips, but any big pair of pliers will work. looks good and good luck
eric j
Red520
I got the cam plate and the cam and I have installed them it works great going into reverse but forward is stiff. I loosened the nut on the cam plate to free it a little more. The edges of the cam plate are newly cut so I imagine it will take a while to wear in. When I pull the hydro lever back it comes to an abrupt halt and about throws me over the hood. I hope it wears in soon.
  • Similar Content
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
