BigRedGrizzly
1970 GT14 Resto
WHX??
18 hours ago, BigRedGrizzly said:
I wish I had a bigger compressor
 Sounds like you need to run a air line from Aldon's shop to yours ...he's got a dandy!
I think @Shynon extended his HF blaster with a simple trash bag to get a frame in? ...maybe he will chime in.
ztnoo
Aldon could supply air to the hobbyists of the greater Glens Fall/Saratoga Springs area.
All that's needed is the infrastructure to delivery the commodity.
He could command a retainer on a monthly basis, per user, to cover the electric bill to operate the beast of a compressor he has.
He could shut anyone off at any time if they don't pay their monthly installment.
Let the users figure out the infrastructure with a bond issue, perhaps subsidized by the county and /or state.
Aldon
I ended up trying to get the largest compressor I could afford because like @BigRedGrizzly I was hampered badly by the insufficient system I had and could not abide the lengthy wait time for the air to build to point I could blast again.
I will say having plenty of air has raised my level of satisfaction and enjoyment of the process.
WHX??
paint to dry so I use the missus oven for a paint dryer.........:laughing-rolling:
Aldon
I resemble that remark!
ztnoo
I promise not to tell.
Inquire privately about muting invoice.
:ROTF:
Shynon
23 hours ago, BigRedGrizzly said:
Not sure what I'm going to do about the frame yet. It definitely doesn't fit in the cabinet
Here's a few mods to my harbor freight blast cabinet. Added 6" to the bottom. Also taped a garbage bag over the door opening when doing my 1045 frame.
  • Like 8
Aldon
Is the extra depth for additional height of pieces needing blasted or for additional media capacity?
Shynon
Just now, Aldon said:
additional height
:text-yeahthat:
BigRedGrizzly
Man.... I feel like this is going to take forever... Some pieces clean up really quickly and easily. Others require more time. I need to get a subscription to that compressed air company you guys were talking about. : )  That or a much BIGGER compressor. The compressor I have now was given to me by a friend and it's very functional. It's intended purpose was for impact wrenches and inflating tires.
Anyways... This is the pile of parts I worked on this evening.
 Hood struts, pedal, implement lift bar, and battery shelf holder thingy...
Aldon
Powdercoat and areas with heavy enamel from multiple coats of repaint through the years are tougher to blast free. Also, the media loses its ability or abrasiveness  after a while. I also found that blasting at an angle was a bit more effective.
Edited by Aldon
BigRedGrizzly
Hello Fellas... I took the advice and purchased a polycarbide wheel and grinder. I did the hood tonight. Worked out great. I'd say it took me about an hour to get it where I thought it would be good for primer. The threaded rod that holds the latch in the front sheared as I was taking it apart. I'll have to either find the rod I make one. Here are some pics.
Primed
  • Like 8
Aldon
Your making excellent progress.
I replaced the hood latch bar with all thread. It functions fine but the steel quality is not what it used to be so the rigidity is less and therefore the tension is also less.
BigRedGrizzly
I just looked at the part catalog and I think the part# is 8353. I think it's still available. It's showing as 109-8353. Could it really be still available??  I think it's called a trunnion.
Aldon
It's indeed possible.
However I have had several parts show as available and then I'm told it's really not.
I never tried to order a new one.
BigRedGrizzly
Hi Fellas.. Just missed out on a 42" Wheel horse plow for my GT14. Quick question... Are all the plows compatible with the GT14? I know the GT14 is an odd ball but are the plows the same. ISO 54" snow plow/ Dozer blade for
a GT14.
Thanks.
-D
BigRedGrizzly
Hi all.... More blasting, polycarbide wheel spinning, priming and painting going on.
My fenders have the common cracks in them. I'll be looking to get them welded and a bracket/reinforcement stuck in there to much like Aldon had done to his.
Here are some pics of where I am today.
I have painted the frame and the trailer hitch I have. There are more primed pieces to paint but couldn't get to them today. It was very hot here in NJ so by the time 2PM rolled around it was time to get to the pool.
I pulled the bearings out of the front wheels today and sandblasted them up. Looks like a bunch of media managed to get in there. Any idea on how be sure it's all cleaned out. I mean it's filled with grease too. I did my best to wipe it clean but I'm just not certain it's good enough. How about spraying some mineral spirits in there? Think that would help clean it out?
Next big task for me is to get the rear painted up.
Aldon
I used nitrile gloves, lots of shop towels and kerosene to clean mine out. If you don't, the remaining grease is like a magnet for the media.
Your making extremely good time with your restoration.
My welder did a really good job bracing the fenders but one of them did deform/twist from the heat. When I installed them as the fender straightened it broke loose the filler so I'll likely re-do the filler and paint when I tear it down at some point to finish the hydro foot control.
Im having trouble motivating myself to work in the 90 degree heat. Once temps drop to lower 80's again I hope to catch my second wind so to speak.
Keep up the great work and updates!
  • Like 4
BigRedGrizzly
Thanks, Aldon... I'll be stopping at Walmart on my way home to pick up some kerosene. I also got my decals in over the weekend.
Tuneup
Those poly wheels are the bomb. Went through several. You are making great progress and those decals are a real incentive to keep moving.
BigRedGrizzly
Hi Fellas.... Well, it was like an X rated WWF wrestling match out front of my garage this evening. It was tire mounting time.  All women and children within 800 feet were asked to leave the area as there was a guarantee that a good amount of cussing was about to go on.... The tires are dry rotted so they required some tubes... Later on down the road I may invest in some Carlisles. The rims have been sandblasted and had a polycarbide wheel. Then primed.
Here are some photos of the struggle.
These are the tools I used.
In this photo I have sprinkled both sides of the inner tube with baby powder to reduce the stickyness of the inner to prevent pinching. Then I put a bit of air in the inner tube.
Then I sprayed a bunch of Simple Green around the tire edge and managed to slip it over the rim. All the while trying to keep the inner tube stem closely lined up with the hole.
My niece, Alexa was over and wanted to help out. And when mounting tires it seems as though there is never enough hands or tire spoons around. I gladly accepted her offer to help and put her to work.
All done. :greetings-clappingyellow:
I will share a tip with you all tomorrow or Wednesday on how to paint rims with tires on them. It was a easy tip I picked up from the three wheeler forum I belong to.
  • Like 5
Tuneup
No worries with those huge spoons! And never discount the value of the knees keeping that lower side in the groove. Nice job!
953 nut
Good job, got to get the whole family involved. This could be a calendar shot in my opinion.
ztnoo
It's great to see a daughter get involved in a physical, real world mechanical project with her father.
Too many girls grow up never doing anything physical working with their hands to solve problems that arise around the household environment and not even grasping or having the mental training and experiences about how things get done and how things get fixed.
If they grow up with no background in hands on repair experience, they are left with no mental tools or knowledge of the real world around them, and will always be dependent upon others to solve some of the problems that will occur to them throughout their lives. That can be as simplistic as not knowing how to change a light bulb or knowing where the breaker box is located to turn a circuit back on that has overloaded and tripped a breaker.
There is also a very special bonding that occurs between a father and a daughter when doing these types of projects, which money can't buy.
Kudos to this father and daughter!
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
