ohiofarmer
Raider 10 and others
ohiofarmer
 Hello. i am not new to Wheel Horse, but am new to the old stuff before Toro got into the act. I have a garage queen 416, a well used 520H with a Predator engine, and just bought the Raider 10 for $300.  The Raider is very solid and it mows and adjusts better than the 520H.  I swept the  barn for parts and came up with a much better seat for the raider and mounted it 4 inches higher and added pivots and rear springs to it. Unfortunately, I was mowing weeds and grass higher than the hood and the center mower drive bearing got tight. Should have greased it before use, but now I have the opportunity to go over the entire deck.
 I cannot say how impressed I am with the design and durability of the older machines. I like the simple stuff and the Raider looks as tough as woodpecker lips. Not perfect, but straight with all the original stuff working.
 The original tires were leaking from the sidewalls and they had used that horrible Fix-A -Flat on them that had hardened like glue. nothing worked as the sidewalls were too weak to support removal. An idea hit--So i got out the propane torch and heated the bottom edge of the tire through the rim in about a foot of arc. When the smoke first appears after about a minute of heating I applied the tool and off she came just as slick as you please. I then used a 36 grit segmented disc wheel and finished critical areas with wheels like this http://www.harborfreight.com/4-1-2-half-inch-nylon-abrasive-wheel-94017.html
 and this http://www.harborfreight.com/4-in-80-grit-nylon-abrasive-wheel-with-14-in-shank-60325.html
 Primer and paint and a new tire tube and she works for a fraction of what a new tire would cost. I found some nice small Led lights at Rural King for $15 and they might fit by removing the logo panel at the top of the hood.
  The rear of the frame where the tilting seat pan mounts was also reinforced with angle as it was in poor condition. Just minor stuff ,really on a machine of such experience. Of the two wheels, the polycarbide wheel is also a good choice to strip paint on sheet metal as it leaves not much in swirl marks and can even leave a shiny finish if used with care. Try one.
. I used the 80 grit abrasive wheel to get at the tight radius areas and then finished up by hand sanding
Edited by ohiofarmer
elcamino/wheelhorse
Welcome to :rs:, but as usual we want pictures . Good idea with the torch .
AMC RULES
:WRS:
SylvanLakeWH
:text-welcomeconfetti:
russellmc301
welcome :wwp:
KC9KAS
:WRS:
You are right about the strength and ease of operation of the "old iron".
953 nut
:WRS:   Helpful tip about removing the tire,  :text-thankyoublue:            :wwp:
ohiofarmer
 Thought I toasted a bearing, but the mower belt got beneath the center pulley and then shredded the main belt. I'll take that. However, the cause was dirt and old oil freezing the action of the tensioner pulley. I will replace the delrin beneath the slider bar with formica, get a new belt, and bob's your uncle. I sanded down the sliding tensioner bar and infused it with silicone grease and wiped it dry. The belt guard is gonna stay removed so i can keep it clean. I will also enlarge the hole in the center mount large enough to let me mount new belts without removing the mower.
 Oh,and I was mowing grass that was one foot hIGHER than the hood. I love this machine. My newer Horses would not in any way suffer the abuse I put this one through.
  • Similar Content
    • 84Workhorse
      By 84Workhorse
      '97 520H for sale; Reason for selling; I bought it about 6 years ago when my GT-1800 engine died which I will be re-powering so I have too many tractors and something has to go.
      I can provide more information and pictures if needed.
      Details:
      All shown in pics included in the price. 998 hours; Engine is in good condition 48 in. mowing deck in sound condition, no rust through 42 in. SS snow blower, I used it twice in 5 years, tire chains go with it 42 in. snow blade sat in my storage shed for the last 35+ years. Rear axle bracket does not go with it b/c I have a tiller for my GT All lights and gauges work with the exception of the engine load gauge. The vacuum nipple is broken off.
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
