36" Deck Spindle
By
JackHorse, in Implements and Attachments
Similar Content
By morePEdal
*16 HP Onan Engine, 665.4 Hours
*8 Speed Transmission
*48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
*Nice 42” Mowing Deck, no rot or welds, smooth spindles
*OEM Wheel Weights, 50 lbs. Each
*Chains
*Valves adjusted this summer, runs great!
*Good battery
*Tires All Hold Air
*LED lights all the way around
*Manuals included
Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
Cash Only!
*WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
*COMING SOON: Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
By cJ_3D
Hello helpful Wheel Horse enthusiasts!
Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
So referencing this image here from the service manual for the mower deck (37"):
What exactly am I doing with this adjustment knob and how does it fit into this piece?
Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
Much obliged for the help!
CJ
By PWL216
I took off the drive belt today and brought it to Tractor Supply, measured it there and it was 1/2” x 81”. It’s old and stretched out so I bought an 80”. It went on fine but the tractor isn’t shifting into gear properly. Looking here and on the web, it seems the correct part number is 7473 and the size is 5/8”x82”. Is that correct? Maybe the PO had used the wrong size?
By cJ_3D
Hey all!
Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
CJ
By razorback1995
Hey all,
This pully blew up on me yesterday. Having a hard time IDing the part # or replacements. the 308-8 schematics I've found don't list this part. Its the pully in the front that runs from the motor to the mowing deck.
Thanks in advance!
