Gernzz8 38 #1 Posted January 1, 2016 Happy New Year!......I picked up my first Wheel Horse 3 Weeks ago......I Love It!! I have a 1976 B100 (61-10K802) with a a 5091 8 Speed Transmission. I have been gathering as much information as I can pertaining to my "Horse". I am having difficulty finding parts for an "Overhaul/Reseal Kit" for my Trans/Diff. No issues other than having a little water mixed in with the gear oil, due to a dry rotted/split shifter boot. I flushed it once with ATF and drained. I filled it up again with ATF and have added some Seafoam to clean and absorb water. I plan on running it a little with the ATF & Seafoam before teardown.Any help would be appreciated. All the Best, Danny Share this post Link to post Share on other sites
rmaynard 17,634 #2 Posted January 1, 2016 Unless you need some gears or bearings once you get inside, what you will need is the following: 1 - 3912 Gasket 2 - 100443 axle oil seal 1 - 100442 input shaft oil seal 1 - 100441 brake shaft oil seal All parts listed are still available from Toro, but I would suggest getting the seals from your local NAPA auto parts store using the cross reference in the transmission section. They are cheaper and better. http://www.wheelhorseforum.com/topic/42506-bearing-and-seal-cross-numbers/ File #3 2 Share this post Link to post Share on other sites
Martin 2,134 #3 Posted January 1, 2016 never tried to flush with ATF, but diesel fuel works great in the unidrives for flushing most of the garbage out prior to refilling with motor oil or rebuilding...... Share this post Link to post Share on other sites
Gernzz8 38 #4 Posted January 2, 2016 Hey Martin.....Thanks Bob!! The ATF seems to find all your seal Issues......At the moment, it's the Brake Shaft Oil Seal. I truly appreciate the Speedy...Response....... All the Best, Danny Share this post Link to post Share on other sites
Racinbob 13,250 #5 Posted January 2, 2016 I'm thinking you really don't need to open it up Danny. The seals can be replaced without doing that. It sounds like you're not having any issues with it and you're getting it flushed out good. If it's only the brake shaft seal you might just do that one unless you want all new seals since you're doing it (along with a new shifter boot). Countless times over the past decades I've done just that and it was back to work. Share this post Link to post Share on other sites
Gernzz8 38 #6 Posted January 2, 2016 Ya know, I was thinking the same thing. I want to "work it" for a season and see if she needs anything else before I do a once over (clean, paint, new decals, etc..) next winter. Right after picking up my Horse I found this Amerind-MacKissic 9-WH Shredder on Craigslist. What a Beast (Dangerous) They Honestly don't make machines or tools like they used to. Thank You people for all your help. Danny 2 Share this post Link to post Share on other sites
rick 321 #7 Posted January 2, 2016 ATF has some very good detergent qualities. As for being too thin to protect gears and bearings, there was at least one auto manufacturer that spec'd ATF in the manual trans. I had a 1968 Mustang, 289 w/ a 3 speed manual. In the winter, it sometimes got hard to shift when cold. At the time I worked in a Mopar dealership. As some older members may remember, Chrysler Corporation was slow to introduce a fully synchronized 3 speed manual transmission. second and third (high) were synchronized, but you had to be slick to downshift into low gear while rolling. At any rate, when the buying public started demanding more models with manual trannies, Chrysler developed a proprietary 3 speed manual, but until it was released, they used a Tremco 3 speed fully synchronized transmission. The same transmission as the blue oval crowd! A TSB came out for hard gear engagement in cold weather, specifying the use of ATF to alleviate the problem. I'm sorry to have gotten off topic, and rambled on.... Nice find on the shredder! 1 Share this post Link to post Share on other sites
Gernzz8 38 #8 Posted March 21, 2017 Happy Spring! Well, I have worked my B100 for a little over a year and I am now Certain I will have to open up the trans and rebearing the 5091 Transmission. The input shaft bearing was screaming after using my shredder for my last composting job, just before Thanksgiving. Unfortunately, I couldn't hear it starting to go while the machine was shredding. I hope I won't need a shaft. I remember seeing videos for transmission tear-downs and how "Best" to remove the bearings. Does anyone know where to access those videos? All the Best, Danny Share this post Link to post Share on other sites
953 nut 70,057 #9 Posted March 21, 2017 1 hour ago, Gernzz8 said: I remember seeing videos for transmission tear-downs and how "Best" to remove the bearings. Does anyone know where to access those videos? Not a video, but lots of good info. Share this post Link to post Share on other sites
Gernzz8 38 #10 Posted March 21, 2017 Thank You, Brother Wish Me Luck. 1 Share this post Link to post Share on other sites
953 nut 70,057 #11 Posted March 21, 2017 Any questions feel free to ask, @Racinbob and @stevasaurus are regulars on here and both are great with transmissions. Share this post Link to post Share on other sites
Gernzz8 38 #12 Posted March 21, 2017 Will do. In Steve's post, I was able to find the videos that I remembered. I'll keep you guys posted. 1 Share this post Link to post Share on other sites
stevasaurus 23,861 #13 Posted March 21, 2017 We have a reference section/transmissions at this link... http://www.wheelhorseforum.com/forum/144-transmissions/ In there you will find all the videos and rebuild threads with pictures. My 5060 thread will have videos that will be very close to your transmission. I have not torn down a 5091 yet, but an 8 speed is an 8 speed is an 8 speed. Please feel free to ask any questions. Share this post Link to post Share on other sites
WHX?? 58,324 #14 Posted March 23, 2017 Go here to get what you will need https://www.wheelhorseman1000.com/product-p/0002.htm If you have a 5091 I think you will need his kit # 5 but double check with him. He is @wheelhorseman1000 here. Share this post Link to post Share on other sites
