Similar Content
By CS-17
Sold!!!
Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
I received it in non working order, I have since done the following repairs: To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter. To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted). This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer. Please feel free to CALL me for details or any question! THANKS for looking! -
By Kenneth R Cluley
Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim! Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
By Kenneth R Cluley
Okay engine Guru's, newbie needs some help! Rebuilding older 8 horse and I am new to small engines. I have rebuilt numerous car/truck engines but never a kohler k. I have researched all available videos and really appreciate the small block tutorial by Prondzy. I am at reassembly stage, so my question is, related to timing marks. I have camshaft with centrifical advance which has a groove or line on spacer that engages pawls. does this groove line up with pointed part of casting on inner rim of gear? Also, there is a groove on opposite side of camshaft gear that I believe should align with pointed mark on casting of crankshaft. See attached pictures. Thanks for any help. Just want to be sure!
By Jennifer
Hello everyone! Got a real puzzle here! Husband has visited with some on here by phone, but he is getting really frustrated! Can anyone help us with this tractor! It will be mowing fine, then start dying off and on at different time frames! Temperature out side sometimes seems to play a part but could be coincident. So he has put more and more money in this and not fixed the issue! A list of what he has done thus far!
new Fuel line
new condensor
new points
new carb
new plug wire
new spark plug
Used fuel pump
new coil
new switch
new battery
new head gasket
soaked it with marvel mystry oil
soaked it with sea foam
removed fuel tank cleaned and blew out
cleaned sediment bowl. Brand new one is on its way
changed oil
all 4 brand new belts
By mhlmeader
Hi folks, me and the gal pal were on our way to the wheelhorse motherland ( southbend), to shop for some wedding rings. So we go down little country road see a barn sale, turned around cause I spy a wheelhorse. I ask how much , he said 400$, but someone was suppose to be picking it up. Turns out it came with a sickle bar too. My ears kinda perked up then , cause my dad wants on for his 702. They call the other fella, he passed on it, I offered 300$, we settled at 350$. Tractor runs pretty good, lil smoke when ya goose it, but runs and cuts pretty good. I'm hoping the sickle bar will fit my dad's 702, it's a 50 inch bar. Anywho, here's some pics a serial numbers if anyone has some additional info, or point me in the right direction, would be appreciated, thanks!!!
