three50seven
Best front tires for a snow pusher?
three50seven
What type of tire tread seems to work best on the front of a tractor used to plow snow? I only have experience with Turf-Savers, and I wasn't real impressed. Also, are front weights worth it?
bmsgaffer
tri-ribs will probably steer the best in snow, but if you need all around versatility without digging ruts in soft ground, get vredestein V61's (i am using V61's). They have multiple biting edges when steering and spread the weight out to not dig ruts.
Yes, front weights make a HUGE difference in being able to steer the plow when you are pushing hundreds of pounds of snow. This year I plan on loading my fronts with RV antifreeze (rears are already loaded) in addition to running front and rear wheel weights.
Tri-Ribs:
16_650_8_3_rib_front_white__14133.135178
V61's:
5_rib_white_bg__63158.1326903994.1280.12
DennisThornton
I'm curious as well but have no first hand experience to share, only tidbits from others.  I've read to somehow use a cable in the center of the tire.  I suppose deflate the tire, position the cable loop and re-inflate.  Now I'm not sure how to make the loop, not a smooth one without cable clamps anyway.  Maybe the crimp-on.  I think I also read about a chain loop used the same way.  That I could make!
Point is to have a center something to catch the snow and ice like the center rib catches and improves steering in a tri-rib tire.
GlenPettit
Tri-ribs for sure, and with weight.  Because:
(1)  Wrapping a 'bicycle chain' around a tire is similar (as Dennis said), but the ti-rib rubber is about 1" wide and 1" high and will "dig in" to the snow much better, and without scratching pavement (as Brandon showed in his first photo).
(2)  Steering Control = keeping the tractor straight or making a turn with minimum sliding is what the high-center rib does, and having a lot of weight in front to keep the tire down on & in the snow is what is essential.
(3)  Having the snow thrower or blade down actually lightens the front end/wheels and as the rear tries dig in to move the tractor, it also lightens/lifts the front end, again reducing steering there, thus the need for extra weight (in the wheels and/or hanging on the front).  With the implements up, we have great steering control because of the weight.  Good tires and lot & lots of weight at the back tires will keep you moving, the front weights will keep you from getting into trouble via steering control.
(4)  I do use Lug tires on one Winter tractor and Tri-ribs on the second, Tri-ribs are much better.  Also tire inflation as a noticeable factor,
use 20#psi in the Winter on both front & back, less rubber on the ground ='s more traction (and Winter temperatures will drop 3-4 psi anyway in them).
Edited by GlenPettit
three50seven
Thanks for the input guys, looks like the tri-rib or V61 is the way to go. Does anyone but firestone make the tri-rib? They seem to be really pricey :eek:
bmsgaffer
Not that I have found for the 16x6.5-8.
You can get 4.0x8 if you get some narrower rims (or have an older tractor) and they are much cheaper.
Edited by bmsgaffer
wallfish
 #40 roller chain wrapped around the center of turf tires and it only cost about $20 - $25. (10ft piece with 2 master links) You can deflate the tires to easily remove them if needed. Might not be a good idea on a nice concrete surface but I use them on asphalt.
can whlvr
I use roller chain also,from my snow throwers when I put new chain on them,it works great,we get ice build up here where I live,probally because I have gravel driveway
DennisThornton
I like that!  Already have the weights too!  Would love to see the other end and how you mounted the bracket/support/holder.  Would be going on my C-85 as well!
bmsgaffer
Just wanted to throw in a pic of the V61's mounted up, (sorry the garage is being reorganized):
2015-09-28_08.05.22.thumb.jpg.844d049893
AMC RULES
This is how I've made my horse steer better
:text-yeahthat:     :text-+1:
JERSEYHAWG /  Glenn
your garage looks like my garage. Projects all over. lol
glenn
cheesegrader
I've used tri-ribs on my thrower tractor for two seasons, and the difference was huge.
The narrow central ridge gives the smallest contact area, and the highest force per square inch of all teh front tires I've seen.
They wear like iron, and aren't bad on a dry lawn, but I wouldn't want to make a bunch of turns in wet grass with them.
C-85
Hi Craig,
Here's a couple of pics of the front weight carrier :)Dec_2011_152_mod.thumb.jpg.66a00d95e3934Dec_2011_148.thumb.JPG.c576ca0f72c67148b
  • Like 6
AMC RULES
Looks awesome...
I need one too.
  :handgestures-thumbupright:
DennisThornton
Yep!  I'll be looking for pieces of metal soon.
Thanks for the pics!
PaulC
I bought a cheaper version of the V61's made by Carlisle for 6" rims and they are better then the turfs in the snow but they don't have nearly as large of ribs as the V61's so those probably work much better.
Brandon did you add tubes to protect the rims for the rv antifreeze or just pull the core and fill them up? I have been thinking of loading my tires this year.
@C-85 that's one cool bracket :handgestures-thumbupright:
bmsgaffer
I havent filled the fronts yet, but I plan on tubing them. For some reason one of my V61's  got a bulge right in the tread when they were first mounted without tubes. I dont know if the tire place over inflated them or what, but i dont remember the name of the place I bought them at the Spring Portland, IN show.
You shouldn't HAVE to use tubes as RV antifreeze is safe for metal, but the V61's are supposedly a tube type tire anyways.
I haven't gotten into my rears yet to know if they have tubes or not. I think they are filled with regular antifreeze, so I will probably pump them out next year and refill with something a bit more environmentally friendly.
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
