msdhomeplans@gmail.com
Need help Appraising my 1965 wheelhorse Tractor
Hello
I have this tractor that has been in my family for a long time.  I used to plow driveways with it for money as a 10 year old.   I believe it is a 1965 Wheel Horse lawn ranger.  I am trying to figure out how much it is appraised for or how much it would cost to fix it up to make it into the tractor it should be.
This past winter I replaced the hoses, spark plug, added chains, changed the oil and did some overall work on it.  It has always been garage stored.
Here are some pictures.
Any help would be appreciated.
Thank You
  • Like 7
AMC RULES
As is...    :eusa-clap:
looks like it's all the tractor it ever needs to be.
:WRS:
Value...I'm thinking, somewhere in the $3-500 range...
depending, of course...on how it runs, and your location.
  Edited by AMC RULES
953 nut
:WRS:     That is a very nice family member you have there, well cared for and loved. You didn't tell us where you live and that can have a an impact on the value.
:text-welcomeconfetti:
Thank you for the help.  I live in Cleveland Ohio.  I have it outside in these photos, but it has always been kept in our garage.  I have always wanted to fix it up and find parts that need to be replaced if it is not worth selling.
AMC RULES
With :rs:on your side...    :handgestures-thumbupright:
finding :wh: parts shouldn't be any problem, what does it need?
Terry M
Looks to be in good shape!!   If it was mine, I'd just clean it and repair whats needed to make it run.   Most of the cost would probably go into the engine and maybe the unidrive trans.
Whens the last time it ran...and how well did it run?
slammer302
I think it looks great as it is. PRICELESS :text-welcomeconfetti:
WHX??
:text-yeahthat:  I would say 3-4 Franklins on the market, maybe 5 if someone is really looking to add a LR to his collection. Priceless if it's been in your family that long.....
953 nut
Ohio is a good location for :wh: enthusiasts, between Indiana, Ohio and Pennsylvania you have about half of the :wh: universe. With that many interested people you could probably be able to find buyer at $ 350 to $ 500 with the blade.  :twocents-02cents:     Hope you will keep it, after all it has been a family member all these years.
It runs great.  All it really needs is a new seat and knobs for throttle and choke.  Maybe new front tires.
slammer302
I believe there is a guy in the vendors section that makes new seat covers and eBay usually has throttle and and choke cables for sale
Sent from my XT1080 using Tapatalk
Digger 66
          D I T T O ^ ^ ^ ^ ^
Welcome to Red Square
Everyone here has inspired me to fix it up and pass it down.  Can someone tell me the paint color that is common for this tractor?
953 nut
:text-yeahthat:      There is no official Wheel Horse Red, most of us use the International Harvester Red for the body and Antique White for the wheels. If you have a paint gun it is best to ad a hardener to the paint.         :woohoo:
HorseHead1089
if you want her to look better before picking her totally apart and restoring her, rustoleum regal red is a nice slightly darker shade of red.
Pullstart
welcome to the forum!  'fore too long, you'll be using those trusses on the ground to house the other tractors you'll be snatching up soon!
AMC RULES
I wouldn't repaint it...besides it's only original once in it's life time...
the factory applied work clothes it's wearing now actually look to be in pretty good condition.
A little TLC applied to that little guy would really go a long way towards making it virtually look like new again.
  • Like 4
RedRanger
:text-yeahthat:
Ken B
I'm with the others, some cleaning and a little hand buffing and that Lawn Ranger will look awesome! New correct style seats I believe are available..As far as value... Believe it or not when the original paint is in nice condition such as yours seems to be repainting it could hurt the value... It is yours so suit yourself.
  • Similar Content
    • David414
      By David414
      I don't have any prior knowledge or experience with this plow as I will be a first-time user. Need some help please.
      I brought this well used plow, which I believe is a Brinly PP-500 series as the exploded part view seems to match up with my plow.
      Completely disassembled the plow, removed all rust, primed, painted, (wheel horse red of course) and re-assembled with new fasteners.
      Having trouble with the coulter blade, as it doesn't seem to fit this plow? Please refer to the pictures below.
      It appears to mount only one way, but it seems too big for this plow.  Do I have the right size coulter blade?
      What am I am doing wrong? Also is the front yoke assembly mounted correctly?
      Thanks
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
