Similar Content
By WheelPuke
I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
By Rob R
Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216. He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
By Jon Paulsen
Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
By morePEdal
416-8 with Onan P216 Engine
The good:
*576 hours
*Nice, clean deck (42”)
*Nice Plow
*Wheel Weights
*Chains
*2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
*Original receipts and paperwork and manuals.
*Receipt showing tune-up and changing from the deck to the plow in November 2021
The bad:
*The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
*Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
*I didn’t get a chance to test drive it because of this.
*One front tire goes flat fast, one rear tire has a slow leak.
*He is going to buy a battery before I look at it again on Friday so I can test drive it.
What do you think is the issue? Is it the battery or fuel system?
Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
*He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
He’s asking $500.
By nylyon-(Admin)
I think I am selling my 1987 414-8 with plow, weights and chains. Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H. In that search I stumbled onto a forum which was one day old. There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike. Mike convinced me I didn’t need a plow, but an entirely new tractor.
About a week or so later, I found this 414–8 for sale, and bought it. I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor. I am looking for $550, but like I said this tractor is a bit of a legend!
I have cleaned it up since the pictures were taken.
