Gt 14 321 kohler triangle coil, no spark slow death
By
John Galt, in Wheel Horse Electrical
Similar Content
By WheelPuke
I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
By tractorboy79
I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
Images below of cylinders to show similaritys.
By Gravely Horse
I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
By bigbuck
I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
please call George at 517-499-5678 for more info.
By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
