bizzo15
HELP ME ID MY MOWER DECK
bizzo15
So I bought a 1998 312-8 last year and I love it.  However I'm not a big fan of the rear discharge deck that came with it.  It doesn't chop the clippings up fine enough for my liking.  Anyways the guy I bought it from gave me the recycler attachment for the deck.  I'd like to get some new blades for the deck and hook up the recycler attachment, problem is the serial # of the deck is worn off and least the sticker portion is(not sure if the serial # is stamped somewhere else)  is there a way to properly ID my deck without serial # so I know what blades to get?
Thanks!
gwest_ca
There is a recycler kit that can be added to RD decks model number 86001.
A 42" RD deck that can use the recycler kit is model number 78350 and there may be others.
Then there is a deck that includes the recycler kit model number 78355.
Go into the Manuals library and search using these numbers.
When the page of results opens change the Submission Date to Title and then to Ascending order.
Garry
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42bc010),  with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
