jmack
2000 RPM Cross Brand Compatibility Mowers
jmack
I became a little curious when researching the PTO RPMs of older Wheel Horse, John Deere and Cub Cadets.  I read that "Woods Equipment" fabricated the Wheel Horse D finishing mowers back in the 70's and maybe the 80's and these mowers were belt driven, and I'm guessing had large pulley that appeared to reduce the 2000 RPM to a more manageable/safe speed.
Mike Duwe from other forum (weekendfreedommachines.com) discovered that John Deere and Cub Cadet also had REAR PTOs with 2000 RPMs similar to the D Series Wheel Horses.  Because of this, is it possible the John Deere 260 Finishing Mower and the Cub Cadet L42 Model 349 would fit the D Series Wheel Horse?  I'm not sure of the rotation direction, spline and diameter differences between Wheel Horse and John Deere are, but this would make finding a D Series finishing mower slightly easier.
Woods
Wheel Horse
John Deere
Cub Cadet
Citations:
http://www.weekendfreedommachines.com/discus/messages/335/232953.html?1205075077
http://www.woodsequipment.com/default.aspx
Other Links:
http://www.weekendfreedommachines.com/discus/messages/335/139036.html
Edited by jmack
pfrederi
I may a bit dense but it would seem to me the big pulley would spin at the PTO speed and the blade spindles would be going much much faster..screaming.
The big pulley looks just like the one that comes with my woods L59 finish mower that goes on my Case VAC.  It has a standard 540 PTO and the big pulley spins at that speed and the blade spindles spin faster...Big pulley is 18inch, spindles about 4.5.  I think that jumps the spindle speed to about 2160 rpm.
The pulleys on my WH finish mower are all about the same size so that would make the spindle speed about 2000rpm
Sorry I do not have a picture of the pulley mounted on the PTO shaft
post-1023-0-15936200-1394480309_thumb.jp
Edited by pfrederi
  • Similar Content
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • CS-17
      By CS-17
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $950 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
