Jparkes43
Tachometer
Jparkes43
Hello I have a Wheel-Horse 227-5 with the 17hp kawasaki single cylinder engine and was interested in putting a tachometer on it (just because i won't too) but i need a step by step guide as I'm not sure what exactly i need to do, also if anyone could advise on a good tach to use that would help a lot, while I'm at i thought that i might put a oil pressure/temperature gauge on it.
thank you
James
wheeledhorseman
Hi James :text-welcomewave: to RS and good to have another Euro member aboard. :UK:
Check out this thread
The Kawasaki in the 227-5 has electronic ignition - a little module mounted on the outside of the engine tinwork replaces the points in older engines. There's no 'coil' it's a magneto type ignition. Not sure how the tacho mentioned will work with this but it's rare to find a tacho like this that will actually operate on a single cylinder engine.
I guess it's a matter of checking with the supplier re the electronic magneto ignition bit.
Hope this helps you a bit.
Andy
p.s. don't forget to intorduce yourself in the Euro tractor section - lots of friendly helpful guys both sides of the pond.
Edited by wheeledhorseman
Jparkes43
Thanks for the reply
is the little module silver?, i will say hi in the euro section
wheeledhorseman
Sounds like you've found it but to be certain it looks like this.
It basically replaces traditional points hence it's earthed through the case and the other wire goes to the primary coil of the magneto under the flywheel. So if a tacho like the one in the other thread is happy with this type of ignition then my guess would be that it would take the pulse from this wire.
For possible future reference - Kawasaki used two different trigger modules on their range of mower engines. They are distiguishable by the spade connector either being on the right or on the left and are not interchangeable (I guess the timing is different). The Kawaski part is expensive but I got the OEM product by Bosch from an ebayer in Thailand for a fraction of the cost.
Keep us posted on progress with the tacho and any other products suitable for a single cylinder ignition system you come across.
Hope this is useful.
Andy
Jparkes43
Yes that is exactly what i was thinking of!
so would i just tap into the black wire with the right taco gauge input wire
meadowfield
These tachs only work with 4,6,8 cylinder engines so it will read wrong.
One and two cylinder tachs are hard to come by, I started looking at modifying my own. There's a thread somewhere, still need to finalise it....
Jparkes43
oh ok i will continue to look
meadowfield
You can buy cheap digital that will work on 1,2,4,6,8....
Coadster32
Could you post a link to this??
meadowfield
Look up digital tachometer on that auction site.
Around 10-15 bucks, sensor wire wraps around spark plug cable...
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
