Uncle Buck
Is this a WH blade?
Uncle Buck
Is this a blade for a Suburban??  (I am trying to figure out how to resize these pictures)
Edited by Uncle Buck
Uncle Buck
xoxoxoxoxox
Trouty56
I'm not sure about the plow....but for the pics...I would ask...how big are they on your computer???  Being a member allows you to upload a certain amount of data but I don't know what that limit is......some upload the pictures to a hosting area like "photobucket" or the like then provide a link to the picture or embed it into the post.  The downside is that the pictures are not still here if you delete them from the hosting site or you allow your account to close.  I am a supporting member and can upload as much as a like here so the pictures will always be a part of the archives for future reference....even if I am not...  Something for you to consider.....
So...back to your dilemma....on your computer try to resize the images to a readable size....I use a program called Irfanview.. http://www.irfanview.com/main_download_engl.htm ..load your image up....select Image at the top....then Resize/Resample....pick something like 640 by 480.....then save it as a different name as what it originally was....then upload the changed image....this should reduce the size of the image so you won't exceed your limit with one BIG picture....
When you want to upload a picture use the More Reply Options (you may already know this) and use the Choose Files... button at the bottom....once the image is uploaded use the add to post button to the right to place the image where the cursor is in the post you are typing.....I try to leave a space below what I type then add to post then leave a space below to start typing again.....
post-1933-0-33943200-1385806477_thumb.jp
so it looks like this....then preview it....then post it.....or add reply....
Uncle Buck
bump,   I got the pics resized, so maybe someone can tell me...........
groundhog47
Looked all through manuals/implements, skipping some and didn't find a match, but it certainly seems I've seen one posted on here similar. The corrugation/bead in the blade is unlike any I've seen posted, but don't discount it as not, yet!
Uncle Buck
No other horse experts here know??? dang..........
CasualObserver
No.  It's not. That actually appears to me to be a cut down 55 gallon drum side, and either home made or otherwise improvised mounting hardware.  Never seen any brand of blade with that rolled bead in the blade.
TT
Resembles the Troy Bilt tiller accessory snow plow, but the mounting bracket is different / altered.
Here's the closest one I could find:  link to expired eBay listing
SousaKerry
I'm betting on home made,  i would say 35 gallon drum though like a grease barrel.
Uncle Buck
I would have to say that you nailed it!
benjiboo
I myself could not say if it is a WH system or not but it doesn't appear to be but it is not the first time I have seen one of those. I went and looked at a model 1067(?) WH tractor that had what appeared to be the same set-up on it. It just bolted on to the sides of the frame rails about the front axle.
  • Similar Content
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Jennifer
      By Jennifer
      Well my husband got new grownup toys!  Lol. Just wanted to post them on here to share!  Sure most seen for sale but they arrived yesterday at our back door glad we found them before it rained again!  Not sure why delivery person made the effort to go to the back of the house…. 🤔🤯
    • Vaughan32850
      By Vaughan32850
      Let’s see all the RJ’s and suburbans that are in Europe / United Kingdom. Here’s my two RJ-58’s.
    • oliver2-44
      By oliver2-44
      So I went to get a haircut this morning in the neighboring town of Kingsland.  Saw a few garage sale sign so I though I'd check them out.   The Garage Sales were a bust, but as I drove through the area, I spotted this 1960 Wheel Horse Suburban being used as a mail box post.    It was chained and locked to the T post and the front rims were sunk well into the dirt like it had been there quite a while.  I momentarily though about knockings on the door,  but the hood was cut, there was no motor and the transmission shifter rubber boot was long gone.  I say it's a 1960 as it had the treadplate foot rest.  It's probable best left for the yard art it's currently being used for.
