nelson or stanley muffler
By
zanepetty, in Engines
Similar Content
By bkarp@roadrunner.com
my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
By Tinman1962
Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
By Little Red Horse
Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
*Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
So I've got 2 questions.
1. What is it worth? (As-Is) and
2. What do I need to do to fix it?
Thanks yall!
By Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
By 850ford
I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
Will a standard mount Kohler work, if I remove the cradle?
I am located in Massachusetts
Thanks
