Glenn Killebrew
Clutch
Glenn Killebrew
I have a 1986 Wheel horse model 21-12k803. I have adjusted the clutch rod to give more tension on the main drive belt and at first the tractor responded very well going up and downs hills. As a matter of fact I put the 8 speed trans inot high gear and it pulled a wheelie!! However now it will barely make it up a hill pulling an almost empty cart in low or high gear. Any ideas will be appreciated. :sad:
JimD
I would check the belt first for signs of stretching or excessive wear. Could be time for a new one. Next look at the spring for the clutch pulley to see if it is weak or broken. Next I'd be sure to check the input pulley to make sure there is no slippage on the shaft that would indicate a broken key. Though this isn't the most likely thing to be wrong, it is a possibility. The serial number you gave comes back as a 312-8. Hope this is of some help.
Jim
puddlejumper
Everything jim said in the order he gave it,But last check for sheared key in rear wheel hubs.
Glenn Killebrew
I found the "no clutch culprit". The part in question for those interested was found on jacksmallengines.com and the part number was 105896-03 and the picture number was 18 which was the ARM-CLUTCH ROD roll pin broke thereby disabling the clutch to operate correctly, and as a consequence the tractor would barely move. My lawn tractor was down near my basement which has no driveway and I wanted to limp it back to my garage where all my tools were. In steps McGyver! Remember him on the TV series late 1980’s early 1990’s? I used a nail to substitute for the roll pin the tractor now jumps when I let off the clutch…obviously I have some more adjusting to do and a new roll pin. I bought the drive belt last year and I didn’t think that it had stretched beyond its working capability. Guys thanks for your help in pin (excuse the pun) pointing a problem which was vague to me.  :banana-tux:
Glenn Killebrew
?do=embed' frameborder='0' data-embedContent>?do=embed' frameborder='0' data-embedContent>
Including a pic of the clutch arm with my substitute nail to limp my horse home to my garage. Will purchase a newroll pin tomorrow.  You can copy and paste this link to see a parts breakdown of the clutch arm and roll pin.   http://www.jackssmallengines.com/Jacks-Parts-Lookup/Model-Diagram/TORO/61340/4013
Glenn Killebrew
OOPs! I guess three pictures are better than one. Once you ge to the website go to the second diagram headed clutch, brakd and speed control and scroll down and find part #18.Thanks to JimD and puddlejumper for there input.
  • Similar Content
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
