Charlie Smith
HELP NEEDED!!! PAINT ISSUES....
meadowfield
very similar to mine!   you could see the raider 10 6 speed even with the sticker removed...
Charlie Smith
Seems to be perfect photoshoot ;) lovely conditions there aswell... Ahaha but yes anyway that does seem to be rather dark.. Do you know is that raider a Belgium import? Or Indiana?
Also.. In that first picture i spot a good old trusty cable tie.. Oh how they have helped me many times before... :P
Charlie,
Stigian
It's a Belgium import..
Yep, cable tie's are very handy things  :D
So are we coming to conclusion yet chaps?    Do we have a darker red in the UK? Is it just on Belgium imports?
:dunno: Answers on a postcard please  :laughing-rofl:
Charlie Smith
I'm not sure i mean you have your raider from Belgium showing the colour down below. And mine from Indiana. Doesn't look much different. But.. Back to blaming tools again. Wasn't very good light or set up for pics.
Look down on the gear box and axel on mine there like pretty much the same colour?
Hmmmm..
Charlie
  • Similar Content
    • Tinman1962
      By Tinman1962
      What color is this called n where can one buy some
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • ToroMan
      By ToroMan
      Evening,
      Looking for a known aftermarket paint brand and color number match for my Toro 520xi model #73542. Normally I would have the local auto paint store match a tractor part, but due to Covid, that's not an option right now. Was hoping someone can recommend a color they have used for the same tractor, as I've heard paint with the Toro label is a bad match.
      Thanks!
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • ohiofarmer
      By ohiofarmer
      I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
      I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
      In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
      Just hoping the gurus can offer a bit of guidance
