Dresden Guy
K-341 carb refurb...... Best place to buy carb stuff??
Dresden Guy
Need some advise from the WH aficionados.
Q: I am wanting to rebuild/refurbish carburetors on my K181 (on a B-80) and my K-341 (on the C-160/8).
The C-160 carb is stamped # 45 503 20s. Is that number a Kohler carb or a Walbro?
Q: The number on the inside of the carb venturi is: "30" Does that mean .030", 30mm, ????
Q: The brass choke plate in the venturi has a "K" stamped on it. Does it mean "Kohler" or ????
Q: Where is the best price for buying the gaskets, needle valves, O-ring, and float?? Sten's? Jacks? Kohler? Toro Dealer?
I think the carb on the B-80 is the same as the one on the C-160 - I haven't pulled the B-80 carb off yet?
Garden plowing time is coming soon :greetings-clappingyellow: and there's carb work to be done!!!
Thanks
Steve
TT
I buy my Kohler parts at the local "mom & pop" parts store.
They can use the financial support more than the giant internet companies - and they're more appreciative. :handgestures-thumbup:
Dresden Guy
Terry,
I agree, but so far coming up with "I can't locate that item" (local NAPA and a local repair shop that works on Kohlers). I will keep trying "local". My wife and I own two (2) "local" businesses, and our motto is: Everyday is "Independents" Day for small businesses.
Thanks for the "Carb" download file .......... great reference tool. I am printing out pictures of my carb and heading to the local "mom & pops" again.
Thanks
Steve
rydogg
The kohler carb kit is part number 25 757 01 s I get them for $9.75 or less this kit will fit both the k181 and the k341 these can be found at most parts stores. I buy these in quantity at ebay since the shipping is cheaper or free if you buy several at a time. Supporting mom and pop operations is the best thing to do I work part time for one but I am 30 minutes from the shop so for the cost of fuel and my time I prefer to get most of my parts shipped directly to my door.
Whmaverick
I do support local business but sometimes for real good carburetor work and parts or upgrades you need to know about Brian miller at a-1millers performance inc. great service excellent quality work and his dad just might call ya at 8 o'clock at night and talk a while, just ask me how I know.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
