Rollerman
300 series three point hitch install
Rollerman
Three point hitches are handy & I've seen some nice ones put on Horse's here at RedSquare.
Member "kpinnc" custom build stands out.
Member "stevebo" 3PH is another.
Those are just a couple off the top of my head, there have been several.
I wanted to give it a shot...so I came up with this.
30 second 3PH installation.
Step one.
Step two
Okay I cheated a little bit.
It's a Koplin 3PH designed for ATV use, rated at 200 pounds lift/300 pounds downforce.
Made to fit in a 2" reciever hitch & powered by an electric actuator.
I seen it on Craigslist, haggled with the seller & went after it this morning.
It fit's right in the 2" receiver hitch designed & built by member "smoreau".
312Hydro
Pretty slick! :bow-blue:
SousaKerry
Ouch for $600 bucks I'll build my own
http://www.amazon.com/Kolpin-Heavy-3-Point-Hitch-System/dp/B003UYWUBK/ref=sr_1_49?ie=UTF8&qid=1355853974&sr=8-49&keywords=koplin+atv
Don1977
Doesn't look to hard to copy. I believe you could get it closer to the tractor by making it narrow and bending the lift arms.
Rollerman
http://www.amazon.co...ords=koplin atv
And for $600 bucks I would have passed too.
The slick part of this setup, I can swap it between two tractors with reciever hitches on them or use it on my Artic Cat ATV if I need or want.
KC9KAS
Very neat....and swapping tractors/ATV is a big plus!
kpinnc
That is the ONE thing my 3-point can't do that I wish it could!
Neat set up Stephen!
Kelly
That is a nice easy and quick 3 point, have you tried it with anything?? that far back you might need some weight on the nose.
Rollerman
The 3PH came with a 4' land scape rake & I have a 4' 3PH blade coming.
The camera angle makes it look further from the tractor than it is...it really doesn't set that far back.
I havn't had the tractor out of the garage yet, but when I do I'll get more pics, maybe with an implement.
I have something coming for the front of the tractor that will add plenty of counterbalance....... :eusa-whistle:
Lars
Looks great Stephen..im sure it works good to
Wheel-N-It
Agreed. I like it!
smoreau
Very nice Stephen! I think I could make one if them for my tractor quite easy, just need the time to do it.
Rollerman
Since the picture links are dead & I'm not able to edit the original post.
This is the Kolpin 3  point hitch mentioned above.
I put it on my C85 for the winter.
It sets in Scott's custom HD 2" receiver hitch, cat0, powered by a linear actuator, 2 wire hook up from the battery to a DPDT Momentary switch, that's mounted to a magnet so I can move the 3PH to different tractors or ATV's & down to the actuator.
Yes it hangs out the back farther than a typical 3PH at the cost of portability.
Pics....
Edited by Rollerman
elcamino/wheelhorse
Any more pictures ? What tractor is it mounted on ?
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
