TheCowboy
c-81 8 speed transaxle problem
TheCowboy
Hello Everyone,
Last summer I bought a 1980 WH c-81 for $575.00 to use as a pulling tractor. The low range never work, so I figured when the season was at a slow spot I could split the transmission and try to fix the low range to give the engine a break on the clay tracks. So not the transmission is split, and I am stuck at step 16 on page 46. of this shop manual. http://www.mywheelho...nual_A-1392.pdf
I drilled out the plug... but no spring and ball came out? And the shifting fork arm, what is supposed to be removed in this step, aint coming out. where am i going wrong?
Also, what could possibly be the cause of the low range not engaging?
Thank you very much everyone!
-Cowboy
racinfool40
The spring and detent balls are located in between the 2 shift rails..If you pry the rails up slowly they will come out of the case..but be careful those little 1/4 ball bearings tend to dissappear..lol. the plug you drilled out is just for re-assembly. The high/low shifter will be belowall the other gears.. You will see this once you have everything dis-assembled..I almost bet you high/low shifter fork is bent or broke off this is a common problem with the High/low trannys..
MIKE
TheCowboy
Thank you so much. what would be the best way to pry the rails up?
racinfool40
I use a large flat screw driver to ease the shafts out..
MIKE
TheCowboy
It surely was the shifting fork! Is this something I can weld back together?
Duff
Cowboy, the thinking around here is pretty universally NOT to try to weld shifting fork back together. They're still available, not terribly expensive, and the risk of the welded part breaking and really screwing things up in the tranny is very real. For an otherwise bomb-proof tranny, the hi-lo shifting fork is the Achilles heel of the unit.
JMHO......and :WRS:
BTW, where in Vermont are you located?
Duff :thumbs:
stevasaurus
Cowboy, there are some good transmission threads in the Links Section on the main page. This may be the one you want...lots of pictures.
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
