JamesBe1
Spline stub
JamesBe1
Anyone know where I can get a spline stub for a rear PTO?
The PTO is 1" with 15 splines. I poked around the internet for a few hours yesterday without much luck. Although I believe that JD might use the same dimension PTO on some of their models. There was even a reference to a spline stub, but no part number.
I would like like to know if wheel horse sold one (I'm pretty sure that they did), and what the part number would be. It's not important to me what the source is, as long as it works.
Thanx,
James
SousaKerry
Are you talking about the standard male end on the tractor?
I think I have seen them on shafts at Tractor Supply, may have to buy a complete shaft and cut it down. But I believe there are adapters available that can be cut down also.
JamesBe1
Thanx Sousakerry2,
Odd, the end of my tractor PTO is female. I was down at tractor supply yesterday looking around for an adapter, but didn't see anything that would work Most of their stuff is Cat 1 and above.
I checked their catalog (online and paper), and didn't see what I needed there either.
The shaft for my tiller is female, and it was what I used to determine the diameter and spline count. I think I better check what is on the tractor itself, but I know that it is female also. So, I need a male/male adapter. One side for sure is 1" 15 spline, and I will double check the tractor just to be sure.
Shuboxlover
The end of my PTO is female also.....
JamesBe1
Thanx. I found that I had the wrong yoke end on my driveshaft.
The good news is that, the pto end of the driveshaft is still available from M&D. The bad new is that they want over $700 for it. That is more than I paid for tractor and tiller combined.
The driveshaft yoke with male spline end is still available from Neapa, and I can change that if I want to, but I believe there is a cheaper and easier way:
I found splined shaft at surplus center that I can cut down in length and attach to my driveshaft to make it a male end. It's on order but I haven't received it yet.
I'll post the end results.
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
    • Tap53
      By Tap53
      List of various belt Lengths and Widths text
      Chart belt
      Belts sorted by part number pdf
      4 pages 458KB
      Belts sorted by belt section (cross section) pdf
      4 pages 422KB
