Countdown To Christmas!
JamesBe1
Hardware specs
JamesBe1
I ponder this every time I look at the Wheel Horse Parts lists. I've been meaning to ask, and have finally remember to post the question.
What does the suffix E.S. mean in the wheel horse parts lists? For example "Nut - Hex 5/16-18 E.S."
Also, what grade to restorers generally like to use? Stainless Steel of Zinc Plated? I know everybody has their own preferences, I'm just trying to get a general feel for what the community like in general.
Thanx,
James
WH520
I can't help you on what E.S. means. When I tore my 518H apart I replaced every nut and bolt with stainless.
bowtiebutler956
I used zinc plated, but that is because stainless is expensive, and I'm cheap! :ychain:
Matt :flags-texas:
MalMac
Not sure on the ES. But I do know this, it has been my experience the hardware you get from the big box stores and some of the chain hardware stores is absolute junk. I have been going to regular fastener buisnesses to get quality fasteners. The cost is way more but I am tired of breaking bolts, nuts strip very easily and quality control is non-existant. Some of that hardware that is out there should not be out there because someone is going to get hurt over that junk.
JamesBe1
I almost always replace all the hardware.
Except on those occasions where it's an odd piece, and I'm in a hurry, and/or it's expensive. There are some definite safety concerns with re-using the old hardware too.
I'll admit it - I'm a cheapskate too (just like Matt). I've been either buying by weight at TS, or individually at my local mom&pop hardware store (I like to keep my money in my community).
As for grade, my cheapskate side tells me to buy low grade stuff, but it's starting to gnaw on me doing that. I don't want to overdo it and put grade-8 all over the place, but I do want to use the right hardware. Dunno exactly where the happy medium is.
Still wondering what E.S. stands for. Was hoping one of the more knowledgeable members around here would know. I'm glad I'm not the only one who doesn't.
Duff
I'm with MalMac on this one - if you're going to buy replacement hardware, get it from a reputable hardware store or go to McMaster-Carr. I use stainless on all my rebuilds, figuring the few extra dollars spent now will be well worth it down the road in parts that can be taken back off easily if they need replacement, and heck, they just look sharp!
JMHO....
Duff :thumbs:
WH520
Maybe it means Ex Spensive?? :eusa-think: :lol:
varosd
I'm using stainless on my 520-H just remember to use thread lube.
gwest_ca
Elastic stop.
Some have a small insert in the threads and others are similar to Ny-lock with the top nylon ring.
Garry
JamesBe1
Wow Garry. If there were a prize, you'd certainly be worthy of it. There were 60 views, and you were the only one who knew. I tip my hat to ya!
So these are different from nyloks somehow? I have seen the term "Eslok" on the parts lists before. I assume that is synonymous with nylok.
JamesBe1
Here's the scoop for any who care to know.
Apparently, Eslok nuts can go on in either directions, and Esna (Nyloc) go on in one direction:
http://www.myelec-traks.com/803437.pdf
gwest_ca
Eslok is a patented process that applies the plastic locking material to threads. There is a service bulletin dated May 1988 where WH/Toro quit using set screws with Eslok and went with 242 blue Loctite as a replacement.
Garry
SousaKerry
Eslok is sometimes also referred to as Nylon patch on set screws.
As far as hardware is concerned check out Fastenal, if you work for a company that has an account you can get the industrial prices, or just open an account. You can get whole boxes of bolts for less then the cost of just a few over at the hardware store. Chances are they can get the really weird stuff too and in any material you want. When I did my 655 all the hardware was SS except for a few specialized fasteners like the reduced head serrated head bolts that hold the tin to the dash.
Fun Engineer
I have a combination of SS and zinc plated on my restoration. It was really dependent on my intention to make it look good and last or if I was concerned about strength. I used a number of Grade 8 bolts and nuts like on the transmission and frame to transmission connection. Dash screws and hood latch nuts were chrome. Most engine and other fastners were SS. I had to use zinc for the serrated head bolts also as I could not find them in SS. Some of my hardware was blasted and re-plated in zinc as I couldn't find replacements. I now have a collection of old no longer available parts to re-plate.
Electro12WH
If your doing a for-real restoration, should you use the original style fasteners?
JamesBe1
I think that might depend on the desired quality of the result.
Some people might opt for stronger fasteners than was originally used. It's important to consider that most companies (even wheel horse) use the least expensive hardware that they can in order to keep the costs down and the profits up. I would use the original spec fasteners as a bottom line as far as quality is concerned. But if you are an absolute purist in the matter, you might want to stick with the same grade of hardware as was used. Just my 2c worth.
COMMANDO6
Well I was thinking of using all the original hardware when I do my restoration... :roll:
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
