jones and son
Antique trencher - Any info???
Flatheadpuller
The engine is an AEN or AENL wisconsin. Same engine just one is newer then the other. Its rated at 9.2hp at 3600. I have one set up for pulling open rpm. Good engine. Steel rod with a bearing in it fromt he factory. Tappered roller bearing mains, forged crank and rod. Oil plunger pump splash lube system. Its a plunger pump driven off the cam with a push rod that plunges up and down squirting oil at the two holes in the connecting rod. The rest is just splash from the rod beating the oil to death.
jones and son
well i got my gas line cut in today,it took about 80 minutes to do 62 feet,at 20 inches deep, not bad by my standards
and i didnt break a sweat! the nice powered dirt that it leaves makes backfill a breeze with my raider and a grader blade. I cut trench, laid the line and plumbed up to the regulator,backfilled and threw out some grass seed all in about 3 hours, All i can say is this is WAY better then a shovel! And this thing purred right along,Thinking i should start a custom trenching biz.
SousaKerry
Reminds me of the Vermeer trencher my dad owns it is powered by a tractor PTO hooked to the front uses the tractor hydraulics also, pulls on a cable usually hooked to a 2nd tractor with the brakes locked on. It may move slow but you'd be surpised how much tile you can do running it for several hours a day for a week or so. One man can run the whole thing but 2 is nice especially when shooting grade with the transit.
jbumgarner
I don't know what it is, but I worked for Ditch Witch in NC for several years and seen many of their first units. I would say its not a Ditch Witch, due to the auger system. The Charles Machine Works (DW) were the first to use a single horizontal auger which revolutionized trenching with their second production service line trencher. The founder was a genius, he also invented one of the first working scissor lifts, but sold the patent to pursue the trenching machines.
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
    • Tap53
      By Tap53
      List of various belt Lengths and Widths text
      Chart belt
      Belts sorted by part number pdf
      4 pages 458KB
      Belts sorted by belt section (cross section) pdf
      4 pages 422KB
