Countdown To Christmas!
IBleedRed
1054 Modification Dilema
71_Bronco
What you could have done is make a cut in the fenders in the vertical portion (where is meets the center section). Then you could weld in a strip of 1" or 2" wide strip of metal in, and then weld the portion of the fenders you cut off back on, thus making them taller.
Also looks to me like you didn't have to cut them THAT far back. Could have left 2 or so inches of the fender portion on and still not rubbed.
SPINJIM
Best place is ebay, or try your local Toro dealer if you don't mind paying a high price. Or better yet, come to the Wheel Horse show in Biglersville, PA in June.
Jim
IBleedRed
I found an add on craigslist for economy parts I'm going to check out first, looks promising. As for the show in PA, I would love to go but its a 5 1/2 hour drive for me and I wouldn't be able to leave for it until Saturday morning.
TT
Speedex tractors would be another source for "clam shell" fenders. There's actually a "NOS" pair of S-23/24 fenders on eBay right now.
You asked about throttle/choke cables...... Are they missing, froze up, broke, cut? :confusion-shrug:
IBleedRed
Its mostly the choke thats the problem, the tab that holds the cable broke off. Niether are beyond repair, but I just wanted to know If there were eny NOS or remanufactured parts out there.
Rollerman
If your not to worried about keeping it 100% correct, browse some of the aftermarket suppliers in the links section here.
Should be able to find some push/pull cables there.
I've seen them on ebay too, but quality varies alot with some of them.
IBleedRed
I'm not going for 100%, but the pull type to me just wouldnt look right.
Dropped out the spindles today to get the new ones welded on. I had to heat up the entire bracket that connects the steering rods to the left hand spindle, and in the proccess managed to crack it. Luckily I was able to braze it back together. Spindles are tacked and just need to be welded. The one picture is the POs fix of the steering rod, so I cut of the end and welded on a proper ball joint.
post-5838-0-70863500-1325815323_thumb.jp
post-5838-0-45804800-1325815335_thumb.jp
post-5838-0-52029500-1325815343_thumb.jp
Rollerman
It's been awhile since I've been around a 953/1054, sorry about that...they do have the lever style & not a push/pull. :hide:
If the levers are in good shape & free, remove the cables & replace.
Most small engine shops or even TSC would have a throttle cable/lever kit.
The cables are just crimped into the lever assembly...it's pretty easy to swap them out.
IBleedRed
I got my spindles and steering arm welded up today. Front end is together and looking good.
The hubs I bought didnt have a grease fitting and I didnt feel like pulling the dust covers off constantly. Decided it would be best to drill and tap a spot for a grease zerk.
post-5838-0-59937000-1325904987_thumb.jp
post-5838-0-44754800-1325904996_thumb.jp
post-5838-0-90386800-1325905007_thumb.jp
Martin
when i did the ones on my 1054, i just bought some generic throttle cable that was longer than what i needed and made them to length. its very easy to do on the 1054, just get the outer length right, allow enough extra length each end for the inner and bend the inner cable ends like the originals. if the end just broke off at the bend, then you have the length you need for the inner, just allow extra past the bend.
IBleedRed
Its not the cable thats the problem, the lever set up that bolts to the dash is whats wrong. The part of the lever mechanism that hold the cable in place is broke off.
Martin
i guess i misread your post. i was lucky that mine were good and the cables were all that needed replacing. im sure you will come across something eventually, sometimes it just takes time.
IBleedRed
I think I've figured out how I'm going to do my 3 point hitch. I can't really explain it, but once I get it finished I'll let the pictures do the talking. Heres what I have do far:
post-5838-0-00355500-1326079574_thumb.jp
post-5838-0-49099500-1326079582_thumb.jp
post-5838-0-76726500-1326079599_thumb.jp
IBleedRed
Gained more ground on my 3 point hitch with the arrival of my lower lift arms and other componants. At the moment I have a chain running to center lift.
Now that I've had time to really look things over and think about Nick's idea of a 3 spool valve and replacing the tractors origonal hydraulic setup with my loader pump is the best way to go.
post-5838-0-12467700-1326259810_thumb.jp
post-5838-0-43054800-1326259829_thumb.jp
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
