MikesRJ
CBR-32 Pitman Arm
MikesRJ
Does anyone have a close-up picture showing both ends of the CBR-32 Pitman Arm? If so, could you post it please.
wallfish
Did you take it apart and forget how it goes back together?????? :omg:
Mine is buried in the shed but I'll se if I can get to it
rickv1957
Mike,I have to ask,what is this pittman arm?,Rick
MikesRJ
John,
Nope (Smart-Arse), I have the manuals and know very well how I took it apart as far as I have gotten so far.
But I cannot, for the life of me, figure out how to get the Pitman Arm off the drive shaft. The shaft is bent and needs to be straightened before restoration. It appears to have been welded at both ends, which does not appear to be original. :D Looking for a picture to figure out what "right" looks like.
Rick,
The Pitman Arm is part number 7 in the following manual;
http://www.mywheelhorse.com/graphics/file/Mowers/CBR-32.pdf
rickv1957
Mike,have one of them mowers purchased,needs picked up,thanks Rick
wallfish
you can solve most problems with a hammer,vice grips and duct tape. :omg:
I don't think looking at mine would be much help because there was some work done on it for that exact same bearing but I'll check on it tomorrow. The drawing makes it look simple though, remove the castle nut and tap it off.
rwilson
In the drawing part 7 is called Pitmanarm assy. I understand that to mean that it is supposed to be one piece and not come apart.? :omg:
MikesRJ
The CBR-32 Sickle Bar Mower is nearing completion:
Well, after getting frustrated I cut the outer band of the guard and got the Pitman Assembly removed. In the process of restoring the unit I also figured out the correct removal technique for the Pitman Assembly.
Once the castle nut and washers are removed, move the Pitman Arm away from the flywheel slightly. Using an "L" shaped small crew driver, push the roller bearing inner race up and out of the roller bearing and remove it from the assembly. Using the same tool, push the roller bearing out of the Pitman Arm end (an inner bearing removal tool may also be used for this step). remove the Zerk Fitting from the Pitman Arm end. The Pitman Arm can now be removed from the within guard and off of the flywheel.
Here's where we started:
  • Similar Content
    • chompinthebit
      By chompinthebit
      This is my 1959 rj-58 I bought from the original owner and the CBR-32 sickle bar that came with it. I replaced all the cutter knives on it.
      DAFC7D56-BB72-4240-84EA-F586B646A599.MOV
    • stevebo
      By stevebo-(Moderator)
      I found this at the flee market today. I know KenB was there before me and he must have missed it Can anyone tell me what models this one fits? I am 99% sure it is for the RJs Got it home, put some of my "used oil" potion on it and it moves nice. All the teeth are in place and will make a nice addition.
      Paid $25 bucks for it...
    • CasualObserver
      By CasualObserver
      Can someone please post up some good clean shots of a full and correctly mounted CBR-32 with belts, engagement pedal and all?  I've spent an hour looking though old posts, and can't find a good shot of a complete one installed.
      Posted here and/or in the gallery  be appreciated.
      Thanks!
