Jim Turner
Wheel Horse 953/1054 Engine and transmission upgrade
Jim Turner
Has anyone upgraded the K241 engine from their 952/1043 to a 12HP K301 engine? Thinking the engine from a 1257,1267,1277 or a 1276 would keep the same original look (starter Generator). From my research the 3 speed transmission (after swapping in the longer 953/1054 axles) from a 1257 or a 1057 would bold right up. Then you would have a heavier duty transmission as well. Has anyone here made those mods? I have a feeling some of you have. I feel the K301 would run that big 48" deck a little better. This is my 953 I did not do the restore on it bought it that way. Right now the transmission shifter is not working and the part I need to get too is hard to reach I may need to remove the transmission to fix it.
  • Excellent 8
oliver2-44
Very nice looking 953
Some on here have swapped in a 6 speed transmission and like the 3 speed, the brake linkage should be a direct fit.   Is your current transmission in good condition?  Seem I’ve read where someone had swapped the differential to a heavier one. Maybe @stevasaurus @953 nut could share some comments about that possibility.
Edited by oliver2-44
squonk
I swapped in a K321 into my 953. Any year will work. Just swap the engine sheet metal over for " the look"  You can use the short big block air cleaner instead of the oil bath if you want. It just fits.
I used the late 60's era sheet metal on mine.
  • Excellent 6
953 nut
I used the sex speed transaxle from a 1267 in one but used the bevel gear differential and axles from the 953. The only alteration needed was the elongation of one mounting hole in the "F Plate" and drilling and tapping a hole in the transmission to line up another mounting bolt. I could have used ten pinion limited slip differential from the 1267 if I replaced the axles with a pair from a GT-14.
The 953 didn't come with an engine and I had a good 12 hp Magnum on hand so that was kind of a no brainer. I was building it as a mild custom anyway so the nostalgic S/G  look was not important to me on this build.102_2949.JPG.66ab648d1daaa5b1a1ddd9a926e9edd8.JPG
  • Like 4
  • Excellent 3
  • Confused 1
Jim Turner
Thanks, I would like more information on how they swapped a 6 speed into the 953. the 953 has much longer axles and I read they do not mate up to the internals of any of the 6 speed transmissions. Unless of course my source was wrong. Yes my current transmission is good except I need to sort out the issue of the shift lever not working properly some kind of set screw issue. I figured the only way to make a 6 speed work would be to have custom axles machined. but would be interesting to know how he may of made it work. Thanks for the reply.
Jim Turner
Very nice.
Jim Turner
That is some very good information, Thank you 953 Nut! Can a 8 pinion differential work in the 1267 transaxle while using the GT-14 axles?
953 nut
Yes, many people prefer the eight pinion and they are very strong units. Interchangeability of parts is one of the best parts about owning a Wheel Horse. Be sure you get the snap rings with the axles, they are much heavier than the hardware stores have.
The GT-14 also came with a limited slip ten pinion differential. The end plates from six speeds were aluminum (left) and the GT-14 and later model eight speeds that had limited slip units had cast iron end plates (right).
Some GT-14s used the standard 1533 bearing to carry the differential (left) and some used the Torrington B-348 roller bearing with a race made by Wheel Horse (right) , otherwise they are all interchangeable amongst Sundstrands and Wheel Horse manual transmissions.  If you were getting a  GT-14 axles and differential wirth the race on it but wanted to use 1533 bearings the races could be cut off the end plates, no problem.
I've never tried to use them in an Eaton but I'm not sure they would work.
Please keep posting your progress.
Edited by 953 nut
fat finger
  • Excellent 2
Jim Turner
Thank you for taking the time to answer my questions.
Jim
oliver2-44
@Jim Turner Search for a thread titled “Wheel Horse Differentials”.
