Jim Turner 73 #1 Posted 2 hours ago Has anyone upgraded the K241 engine from their 952/1043 to a 12HP K301 engine? Thinking the engine from a 1257,1267,1277 or a 1276 would keep the same original look (starter Generator). From my research the 3 speed transmission (after swapping in the longer 953/1054 axles) from a 1257 or a 1057 would bold right up. Then you would have a heavier duty transmission as well. Has anyone here made those mods? I have a feeling some of you have. I feel the K301 would run that big 48" deck a little better. This is my 953 I did not do the restore on it bought it that way. Right now the transmission shifter is not working and the part I need to get too is hard to reach I may need to remove the transmission to fix it. Share this post Link to post Share on other sites
oliver2-44 11,837 #2 Posted 1 hour ago (edited) Very nice looking 953 Some on here have swapped in a 6 speed transmission and like the 3 speed, the brake linkage should be a direct fit. Is your current transmission in good condition? Seem I’ve read where someone had swapped the differential to a heavier one. Maybe @stevasaurus @953 nut could share some comments about that possibility. Edited 1 hour ago by oliver2-44 Share this post Link to post Share on other sites
