sqrlgtr
widen rear wheels
c-series don
I think we are all forgetting about the fact that wider wheels just look cooler! 🤣🤣
  • Excellent 3
  • Heart 2
ebinmaine
Just now, peter lena said:
@ebinmaine   @sqrlgtrwas thinking  about , relatively  light  weight  for that  tire width , winter traction , favors  narrower , with chains , for  slippery grip , pete
On paper you're correct but my own experience shows me that the extra weight of a wider tire and more fluid is VERY beneficial.
There's also another couple inches of metal from the chains biting the ground.
Handy Don
The coefficient of friction, area, and normal force the keys, right?
Tread, chains, and ground condition determine the coefficient. Contact patch governs area. Weight is the normal force. They all must play together!
  • Excellent 2
sqrlgtr
Got um welded together. Found some old aluminum siding and cut me a strip out and used thatvas a backer for my weld and it worked great. I had them tacked in 3 different places and just welded a1 1/2 to 2 inch bead rotatiing wheel to a different spot trying to keep heat down a little. Ran out of supplies (primer, Bondo, sandpaper etc.) and had to quit for the day. Opie took care of some business while we where at shop also. He is a groundhog killing mochine. This is the eighth one Ive seen him kill and he has probably killed more than that :D
  • Excellent 8
Handy Don
1 hour ago, sqrlgtr said:
Looking good!
ineedanother
I find the domestication of dogs fascinating. They can turn their primal instincts on and off beyond our ability. It's no wonder they're such good companions.
ebinmaine
Most can. Not ours. That's what makes her "special"....
We've tried all types, sources and levels of training & correction. Cain't be fixed.
But she's a wonderful house dog!
sqrlgtr
Opie is ruff (pun intended) on the groundhogs but has never met a stranger and loves people. Everyone said he would have made a good therapy type dog. IDK if they would feel the same after watching him do battle with them groundhogs, they are by no means easy to kill.
  • Excellent 2
953 nut
Got to agree with both of you,  a good looking trailer queen needs good traction hen being loaded onto the trailer.          :handgestures-thumbupright:
  • Haha 1
sqrlgtr
Im slow but I am getting there. You know how it is an hour here and a few minutes there making shop time. Ready for final wet sanding and then some paint. Any recommendations for a rally color that closely matches the Wheel Horse silver/Rally color? I believe I will break out the spray gun instead of using spray bombs 💣. Its been hit and miss on the spray bombs lately some sprayed ok and then a few was awful:bitch:.
  • Excellent 2
ebinmaine
@kpinnc or @JCM  ?
What brand?
sqrlgtr
3 hours ago, ebinmaine said:
@kpinnc or @JCM  ?
What brand?
Rustoluem, sometimes I wonder if it is where I get it from and think it may be getting a little age on it.:o
Edited by sqrlgtr
JCM
@kpinnc or @JCM  ?
What brand?
Eastwood Rally Wheel Argent Silver is said to be a very close match. Never used it , but have known others that have in the spray bombs. A General motors match. Good luck.
ebinmaine
With the 2X line we've had very good experiences. The others can vary a little...
Bar Nuthin
I like the 2X drying time, but lately I've been using the "5 in1" with the multiple spray patterns. I've not had any spray issues and it let's you lay down a beautiful smooth finish!
sqrlgtr
The only thing that I have found around here was some primer with the 5 in 1 spray nozzle and it did seem to make a better pattern, but I haven't had a chance to try actual paint with that style nozzle.
Bar Nuthin
kpinnc
19 hours ago, ebinmaine said:
What brand?
I'm inclined to agree with @JCM
The Eastwood kits I've used have a base coat and clear in rattle cans. It lays down well and the clear offers good protection. It's a bit brighter and glossier than OEM, but it wears in good over time.
sqrlgtr
Got um painted ended up using Rustoleum Metallic. Its closest thing I could find local. I thought they turned out pretty good fer spray bombs. They actually look better in person than in pic’s, sun was really shining, and believe they will match factory closely after they get dirty and washed a time or two. Going to wait untill Monday before mounting tires to let paint cure a little. They are dry to the touch all ready definitely cures faster than the Regal Red spray bombs :D.
  • Like 6
ebinmaine
Order online.
I'm ALL FOR supporting local businesses but they just don't have the space or financial resources to stock a bajillion different paints.
sqrlgtr
I
23 minutes ago, ebinmaine said:
Order online.
I guess I should rephrase "all could find". Local Auto paint supply store had what I needed but time I bought reducer, hardner and a quart of single stage enamel paint they were wanting almost $350 for everything. I know everything goes up but I can order everything online for a 1/3 of that price with free shipping.
Edited by sqrlgtr
sqrlgtr
7 hours ago, kpinnc said:
@kpinnc are those 26x12x12 rears and did you have to modify the fender/seat pan to get them to fit? I apologize if I have asked before my memory isn't what it used to be.:wacko:
Edited by sqrlgtr
sqrlgtr
Wheels done and Tires mounted (26x12x12)’s on the 520H. Had to massage rear fender to get un tucked under there. Has been a fun project and glad I tackled it. Would I do it all again heck yeah. Ivstill cant get over how bright they appear in pics they are not as bright in real time.:D They have more clearance in real time than what appears in pics.
Edited by sqrlgtr
  • Like 4
kpinnc
On 10/16/2026 at 8:17 PM, sqrlgtr said:
26x12x12 rears
They are oddball 25x13-12. ATV tires have some strange sizes!
sjoemie himself
On 10/19/2026 at 9:17 PM, sqrlgtr said:
That's tough! Great work.
What tires are these?
