FLtractor 215 #1 Posted Saturday at 11:50 PM Evening, is it necessary to lube 856 pulleys and belts? If so with what and how often? All pulleys including S/G? 2 Share this post Link to post Share on other sites
adsm08 5,104 #2 Posted Saturday at 11:58 PM You don't lubricate belts, or the contacting surfaces of their pullies. Belts need friction to move or be moved by a pulley. Lubrication removes friction. The result would be ruining your belts. 1 1 Share this post Link to post Share on other sites
ri702bill 12,942 #3 Posted yesterday at 09:45 AM If you were thinking of the "Miracle in a Can" Belt Dressing Spray - don't use it. Do it right - belts run dry. The V surfaces on the pulleys should be free of paint & rust. Share this post Link to post Share on other sites
Retired Wrencher 6,966 #4 Posted yesterday at 09:52 AM I believe the bearing are sealed so no lube there. The ones I have and had were all sealed. Now if your talking deck that is a different story. Share this post Link to post Share on other sites
953 nut 68,965 #5 Posted yesterday at 12:11 PM Is your belt squealing not sure where you are going with this question Don't think it would be a good idea. @peter lena, what do you think? 1 Share this post Link to post Share on other sites
adsm08 5,104 #6 Posted yesterday at 12:20 PM 2 hours ago, ri702bill said: The V surfaces on the pulleys should be free of paint & rust. And glaze. If a belt has been slipping it is not a bad idea to take some coarse sand paper and rough the surface up a bit. 1 1 Share this post Link to post Share on other sites
ri702bill 12,942 #7 Posted yesterday at 12:45 PM and rough it up a bit.... Treat it like a red-headed stepchild! No, actually, he brings up an excellent point. Insufficient belt tension can lead to slipage & surface glazing... 1 Share this post Link to post Share on other sites
adsm08 5,104 #8 Posted yesterday at 01:07 PM 20 minutes ago, ri702bill said: and rough it up a bit.... Treat it like a red-headed stepchild! No, actually, he brings up an excellent point. Insufficient belt tension can lead to slipage & surface glazing... I had this issue on my deck pullies last year. Even with sharp blades and new belts it was slipping in thick grass. I had to get in the single pulley with some 80 grit and bust the glaze off the surface. 2 Share this post Link to post Share on other sites
peter lena 10,043 #9 Posted 5 hours ago @ 853nut , my experience with belt fraying is , related , bearing lubrication failure , GLAIRING TO ME , usually has a rough , movement stage to it , lucas extra hd green chassis grease , into a wiped out , flushed bearing , hand repack , all my bearings have this , except outer pto cone bearing , napa , the pto lever smooth easy engagement says it all . never burned out a clutch disc , grease has a 550 deg drop point , AND POLYUREA RATING ? so it stays with bearing . try something , pete Share this post Link to post Share on other sites
953 nut 68,965 #10 Posted 2 hours ago 3 hours ago, peter lena said: , my experience with belt fraying is , related , bearing lubrication failure , GLAIRING TO ME Pete , you are too serious. FL was asking what grease to put on his belts and pulleys and I invited you in to have a good laugh. Share this post Link to post Share on other sites
peter lena 10,043 #11 Posted 1 hour ago @953 nut interesting to me , is there are so many units around me that are like train wrecks , just total neglect , try and ignore most of what I see , read , been doing this for too long , coming to my end of it , pete Share this post Link to post Share on other sites
