FLtractor 208 #1 Posted 13 hours ago Evening, is it necessary to lube 856 pulleys and belts? If so with what and how often? All pulleys including S/G? 2 Share this post Link to post Share on other sites
adsm08 5,087 #2 Posted 13 hours ago You don't lubricate belts, or the contacting surfaces of their pullies. Belts need friction to move or be moved by a pulley. Lubrication removes friction. The result would be ruining your belts. 1 1 Share this post Link to post Share on other sites
ri702bill 12,939 #3 Posted 3 hours ago If you were thinking of the "Miracle in a Can" Belt Dressing Spray - don't use it. Do it right - belts run dry. The V surfaces on the pulleys should be free of paint & rust. Share this post Link to post Share on other sites
Retired Wrencher 6,962 #4 Posted 3 hours ago I believe the bearing are sealed so no lube there. The ones I have and had were all sealed. Now if your talking deck that is a different story. Share this post Link to post Share on other sites
953 nut 68,945 #5 Posted 1 hour ago Is your belt squealing not sure where you are going with this question Don't think it would be a good idea. @peter lena, what do you think? Share this post Link to post Share on other sites
adsm08 5,087 #6 Posted 1 hour ago 2 hours ago, ri702bill said: The V surfaces on the pulleys should be free of paint & rust. And glaze. If a belt has been slipping it is not a bad idea to take some coarse sand paper and rough the surface up a bit. 1 Share this post Link to post Share on other sites
ri702bill 12,939 #7 Posted 51 minutes ago and rough it up a bit.... Treat it like a red-headed stepchild! No, actually, he brings up an excellent point. Insufficient belt tension can lead to slipage & surface glazing... Share this post Link to post Share on other sites
adsm08 5,087 #8 Posted 29 minutes ago 20 minutes ago, ri702bill said: and rough it up a bit.... Treat it like a red-headed stepchild! No, actually, he brings up an excellent point. Insufficient belt tension can lead to slipage & surface glazing... I had this issue on my deck pullies last year. Even with sharp blades and new belts it was slipping in thick grass. I had to get in the single pulley with some 80 grit and bust the glaze off the surface. 1 Share this post Link to post Share on other sites
