953 nut
What belt does my Wheel Horse Take? Take a Look!
Lee1977
I see you found it 7478.
Edited by Lee1977
sqrlgtr
Dick, if you need another project trans seals and woodruff key simplified list would be nice. :hide: BTW great job...
  • Haha 1
953 nut
3 hours ago, Lee1977 said:
On 69 and 70 Charger 9 &10 either the WH number or the length is wrong,
would you be so kind as to give me the correct numbers before the opportunity it edit closes.
953 nut
You have my blessing to put that on YOUR to do list.         :ychain:
  • Haha 1
gwest_ca
Many of the Woodruff keys are in this file description using the original number. Click on the fuzzy part of this link to see them.
953 nut
@stevasaurus already covered that one very nicely.
peter lena
@953 nut  went over to  T/S ARIMID BELTS LONG AGO , what do you think was my  most effective change to my  belt set ups ? regularly  refer to INCREMENTAL  PULLEY  HANG UP aka , lubrication failure . BELT BOUNCE , AND RELATED CRACKING / FRAYING IS SHOWING YOU THE WAY ?, never  burned  out a pto  clutch disc , also detailed in my pto / mule drive , lever set up , thats a GOLD MINE FOR FUNCTIONAL ENHANCEMENT . every related bearing , lucas xtra hd , green chassis grease , bearings wiped out / flushed , hand repacked , 550 deg flash point , polyurea rated / anti sling , never had a failure or related  WHYINING , thats telling  you  of issue ?  realise many are  going back for  direct parts , but when it keeps failing , ever a thought to  ELIMINATE IT ? EX, PTO INNER  CONE NEEDLE BEARING ? clean out , dried crusty used to be lube , very lightly lucas green , mine actually spins down after usage , smooth / silent , what am i doing wrong ? also rub down my  horses with  penetrating oil , pete
