953 nut 70,647 #1 Posted September 24 (edited) I have been homebound with the flu for a few days and decided to take on a project that has been on my mind for some time. We are blessed to have a chart of drive belt sizes for all models of Wheel Horses, but the way it is laid out it can be a bit cumbersome to deal with and I have reconfigured the information in a manner I hope will be easier to use. I haven’t included all models and I apologize in advance for any mistakes or omissions I may have made. I have also included a few other tidbits. Tractor drive belts Drive belts should be fabric covered 58 – 59 RJ 1567 4L - 29 60 – 61 SUBURBAN 1569 4L -29 1961 and later Horizontal crankshaft Wheel Horses can be divided into four categories, Short Framer, Mid Frame, Long Frame, and Estate Tractors. Here is a list of short frame (41.25" Wheel Base) manual transmission Wheel Horses. All use Wheel Horse Belt # 9691 ½” X 70” cloth covered drive belt. 1961 - 701 1962 - 502, 552, 702, Lawn Ranger 1963 - 603, 633, 653, 753, Lawn Ranger 1964 - 604, 654, 704, 754, 854, 1045, Lawn Ranger 1965 - 605, 655, 855, 1055, Lawn Ranger 1966 - 606, 656, 856, Lawn Ranger 1967 - 607, 657, 857, 867, Lawn Ranger 1968 - Commando 6, Commando 8, '500' SPECIAL, Lawn Ranger 1969 - WORKHORSE 700 Short frame 8 HP Hydrostatic Transmission Wheel Horses. All used Wheel Horse Belt # 8005 ½” X 72” cloth covered drive belt. 1965 – 875, 1075 1966 - 876 1967 - 877 With the exception of some 8 HP models and Estate Models all Wheel Horses from 1966 on were long frame, we will cover the exceptions first. Estate models, 953, 1054, 1054A , 47” wheel base Wheel Horse Belt # 1592 ½” X 82 cloth covered drive belt GT-14, 48” wheel base Wheel Horse Belt # 8334 5/8” X 83” cloth covered drive belt Mid Frames Some 1972 to 1975 Wheel Horse 8 horse powered models had a wheel base of 43 inches there is a bit of inconsistency in the belts used for the A models in this period so check the chart. Long frame, 45-1/2 inches. Wheel base began wit the 1966 10 HP and 12 HP models. From 1969 on and any Kohler powered long frame manual transmission Wheel Horse used a Wheel Horse Belt # 7473 5/8” X 82” From 1969 on and any long frame Hydrostatic with a Sundstrand transmission (except the Estate models) uses a Wheel Horse belt part # 108501 5/8” X 82” From 1969 on any Kohler (including Twins) powered long frame Hydrostatic with an Eaton 700 or 1100 transmission uses a Wheel Horse belt part # 108501 5/8” X 82” From 1989 on any Onan powered long frame Manual or Hydrostatic transmission uses a Wheel Horse belt part # 114895 5/8” X 83” Tractor drive belts Drive belts should be fabric covered 58 – 59 RJ 1567 4L - 29 60 – 61 SUBURBAN 1569 4L - 29 61 – 67 SHORT FRAME GEAR JAMMER 9691 ½ X 70 953 – 1054 1592 ½ X 82 69 – 70 VERTICAL ENGINE 8133 ½ X74 69 – 70 CHARGER 9 & 10 7478 5/8 - 84 GT-14 8334 5/8 x 82 12 HP KOHKER - SUNDSTRAND 7478 5/8 x 81 12 – 16 HP KOHLER GEAR JAMMER 7473 Changed to 93-9808 in ’96 5/8 x 82 12 – 16 HP KOHLER WITH EATON 108501 5/8 x 82 17 – 18 HP KOHLER GEAR JAMMER 107939 Changed to 93-9809 5/8 x 83 417 – 418 KOHLER WITH EATON 108501 5/8 X 82 416 - 520 ONAN GEAR JAMMER 107939 Changed to 93-9809 5/8 X 83 416 – 520 ONAN EATON 141895 5/8 X 83 Drive belt sizes WHEEL HORSE PART NUMBER BELT SIZE Starter/generator belt Kohler 10hp, 12hp Kohler # 235262 3L-35 Notched raw rubber edges NAPA 25-7345 Kohler 7hp, 8hp Kohler # 231605 3L-32 Notched raw rubber edges NAPA 25-7315 S/G indicator Light bulb #57 Replacement light unit Cole-Hersee PL 20 RC HY-2 or HY-3 1584 3L-510 953 – 1054 Hydraulic pump belt 1591 3L-480 What are the differences between the various Wheel Horse Belt part #s on the same size belts? ? ? I have seen belts sold on the internet using the TORO/Wheel Horse part numbers that won’t work because they are too wide and I have used the Tractor Supply replacement belts with good results. Use your own judgement. Edited September 24 by 953 nut 7478 1 3 9 Share this post Link to post Share on other sites
Lee1977 7,813 #2 Posted September 24 (edited) I see you found it 7478. Edited September 25 by Lee1977 Share this post Link to post Share on other sites
sqrlgtr 4,224 #3 Posted September 24 Dick, if you need another project trans seals and woodruff key simplified list would be nice. BTW great job... 1 1 Share this post Link to post Share on other sites
953 nut 70,647 #4 Posted September 24 3 hours ago, Lee1977 said: On 69 and 70 Charger 9 &10 either the WH number or the length is wrong, would you be so kind as to give me the correct numbers before the opportunity it edit closes. Share this post Link to post Share on other sites
953 nut 70,647 #5 Posted September 24 3 hours ago, sqrlgtr said: Dick, if you need another project trans seals and woodruff key simplified list would be nice. BTW great job... You have my blessing to put that on YOUR to do list. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #6 Posted September 25 Many of the Woodruff keys are in this file description using the original number. Click on the fuzzy part of this link to see them. 1 Share this post Link to post Share on other sites
953 nut 70,647 #7 Posted September 25 18 hours ago, sqrlgtr said: if you need another project trans seals @stevasaurus already covered that one very nicely. 1 Share this post Link to post Share on other sites
peter lena 10,123 #8 Posted September 25 @953 nut went over to T/S ARIMID BELTS LONG AGO , what do you think was my most effective change to my belt set ups ? regularly refer to INCREMENTAL PULLEY HANG UP aka , lubrication failure . BELT BOUNCE , AND RELATED CRACKING / FRAYING IS SHOWING YOU THE WAY ?, never burned out a pto clutch disc , also detailed in my pto / mule drive , lever set up , thats a GOLD MINE FOR FUNCTIONAL ENHANCEMENT . every related bearing , lucas xtra hd , green chassis grease , bearings wiped out / flushed , hand repacked , 550 deg flash point , polyurea rated / anti sling , never had a failure or related WHYINING , thats telling you of issue ? realise many are going back for direct parts , but when it keeps failing , ever a thought to ELIMINATE IT ? EX, PTO INNER CONE NEEDLE BEARING ? clean out , dried crusty used to be lube , very lightly lucas green , mine actually spins down after usage , smooth / silent , what am i doing wrong ? also rub down my horses with penetrating oil , pete Share this post Link to post Share on other sites
