FLtractor 208 #1 Posted Thursday at 05:57 PM (edited) Afternoon, Took my 856 K181 starter gen off tractor to local shop.. they tested it Said it works good and ran a belt on the pulley.. said will crank tractor long as battery charged. But it is not charging so need new voltage regulator Current regulator has 3 terminals front and underneath wire.. can’t find anything online based on the housing #”s. Also should get new S/G belt. Here is current belt and belt from Napa that supposedly fits. Edited Thursday at 06:01 PM by FLtractor Share this post Link to post Share on other sites
953 nut 68,950 #2 Posted Thursday at 06:07 PM Kohler 7hp, 8hp Kohler # 231605 3L-32 Notched raw rubber edges NAPA 25-7315 A fabric covered belt like that will not grip enough to start your engine. 2 Share this post Link to post Share on other sites
FLtractor 208 #3 Posted Thursday at 06:26 PM (edited) 23 minutes ago, 953 nut said: Kohler 7hp, 8hp Kohler # 231605 3L-32 Notched raw rubber edges NAPA 25-7315 A fabric covered belt like that will not grip enough to start your engine. Thank you for belt #. Interesting the # on Napa is a cogged belt unlike what’s on my tractor now. regarding the Voltage regulator.. do you happen to know of a solar charger i could hook battery to if i decided not to get new voltage regulator? Edited Thursday at 06:31 PM by FLtractor 1 Share this post Link to post Share on other sites
ri702bill 12,941 #4 Posted Thursday at 06:52 PM Agreed - you need the raw sided cogged belt. It fits tighter on the S/G pulley and does not slip. Did you attempt to diagnose your old Delco Remy Regulator? They are pretty simple... Share this post Link to post Share on other sites
FLtractor 208 #5 Posted Thursday at 07:17 PM (edited) 25 minutes ago, ri702bill said: Agreed - you need the raw sided cogged belt. It fits tighter on the S/G pulley and does not slip. Did you attempt to diagnose your old Delco Remy Regulator? They are pretty simple... Good to know about belt. Didn’t not attempt diagnosing regulator.. not sure how to do so or what to look for.. have link to good video by chance ? Edited Thursday at 07:17 PM by FLtractor Share this post Link to post Share on other sites
ri702bill 12,941 #6 Posted Thursday at 08:49 PM 1 hour ago, FLtractor said: have link to good video by chance Ha - that's funny. No - the info I have goes waaaay back. These files are a lot of knowledge, even with the corny illistrations. Remember that the origin of S/G systems dates back to the 1930's - almost 100 years ago. Delco_Kohler_4-72_SM_Section_07.1-7.6_Starter_-_generator_HR.pdf Delco Remy Regulator Manual 1R-116.pdf delco_remy_regulator_service 1R-111.pdf 1 Share this post Link to post Share on other sites
953 nut 68,950 #7 Posted Thursday at 11:04 PM Check this video out, better than most. https://www.youtube.com/watch?v=W8C26XOFAhM 1 Share this post Link to post Share on other sites
adsm08 5,089 #8 Posted Friday at 12:10 AM The regulators rarely actually go bad or break, unless they were hooked up wrong, or were exposed to an electrical fault. These are old designs, from the days when things were meant to be worked on. They can be cleaned and adjusted and brought back to life as they wear. If you remove the top cover and hold the unit right-side up with the three posts facing you the set of contacts responsible for charging will be to your right. Cleaning them with some fine sand paper and making sure all the other connections are good an clean, and the wires are in good shape, is likely all that is needed. There is a website where high-quality regulators can be purchased still. Of course I can never remember what it is. @ebinmaine Eric, is it you that always has to remind me of that site? 2 Share this post Link to post Share on other sites
ebinmaine 80,491 #9 Posted Friday at 12:17 AM 6 minutes ago, adsm08 said: There is a website where high-quality regulators can be purchased still. Of course I can never remember what it is. @ebinmaine Eric, is it you that always has to remind me of that site? Ain't me. Mebbe @Achto or @WHX?? knows? Share this post Link to post Share on other sites
adsm08 5,089 #10 Posted Friday at 01:05 AM 47 minutes ago, ebinmaine said: Ain't me. Mebbe @Achto or @WHX?? knows? Not me. I can't remember it, and I can't remember who normally, and I am still dealing with some after-effects of that head shot I took last Friday. Share this post Link to post Share on other sites
Achto 32,569 #11 Posted Friday at 10:21 AM Give this regulator a try. https://www.amazon.com/Parts-Player-12V-Regulator-1959-1966/dp/B07Z9LQJDG/ref=sr_1_25 1 Share this post Link to post Share on other sites
Handy Don 17,401 #12 Posted Friday at 03:01 PM 19 hours ago, FLtractor said: Didn’t not attempt diagnosing regulator. If you decide to replace, please don’t discard the original--someone here would likely take it to attempt a refurb. 4 1 Share this post Link to post Share on other sites
squonk 48,014 #13 Posted yesterday at 11:54 AM Things would work better with the rust cleaned off the connections! 2 Share this post Link to post Share on other sites
adsm08 5,089 #14 Posted yesterday at 11:58 AM (edited) 4 minutes ago, squonk said: Things would work better with the rust cleaned off the connections! You are right, but if you look at the OP's full body of work on the forum you will notice a pattern that points towards three things. 1) He likely does have ADHD. 2) He likely does NOT have any Ritalin. 3) He would rather load up the parts cannon than slow down and diagnose something. Edited yesterday at 11:58 AM by adsm08 Share this post Link to post Share on other sites
WHX?? 57,964 #15 Posted yesterday at 12:01 PM On 9/24/2026 at 7:17 PM, ebinmaine said: Ain't me. Mebbe @Achto or @WHX?? knows? Around here the farm & barn & man malls sometimes have them but watch for the 6 volt offerings. I had bought one in the jungle Dan had posted but still didn't get it to charge right. May have had other issues tho and never did get to the bottom of it. 6 minutes ago, squonk said: Things would work better with the rust cleaned off the connections! Share this post Link to post Share on other sites
adsm08 5,089 #16 Posted 23 hours ago On 9/25/2026 at 11:01 AM, Handy Don said: If you decide to replace, please don’t discard the original--someone here would likely take it to attempt a refurb. Yeah, me. I have three on my work bench that I damaged making bad connections that I have since repaired. Depending on what breaks I'm getting pretty good at it. About all I can't do is re-wind the magnet coils at this point. 1 Share this post Link to post Share on other sites
FLtractor 208 #17 Posted 16 hours ago (edited) 11 hours ago, adsm08 said: You are right, but if you look at the OP's full body of work on the forum you will notice a pattern that points towards three things. 1) He likely does have ADHD. 2) He likely does NOT have any Ritalin. 3) He would rather load up the parts cannon than slow down and diagnose something. 1) possibly but undiagnosed 2. correct 3. would much rather slow down and diagnose but not very mechanically inclined and attempting to learn as I go.. reason I bought the 856 when early 2000s John Deere died after 20 plus years . still not entirely comfortable using my cheap harbor freight 7 function muti meter.. need to find better video showing use on tractor or automotive in detail.. did receive some helpful advice on here thank you fellow Wheelhorsian… still need to print out the S/G manuals on here to better learn about that and voltage regulator.. I did read briefly that for voltage regulator should NOT use emory cloth or sandpaper for cleaning connections.. take it that’s INSIDE? But sandpaper ok for all the outside connections terminals for S/G voltage regulator? Will need to open up voltage regulator and clean off the terminal inside that was told on here also helpful Wheelhorsian said usually is reason they not charging. Edited 16 hours ago by FLtractor Share this post Link to post Share on other sites
adsm08 5,089 #18 Posted 16 hours ago 1 minute ago, FLtractor said: would much rather slow down and diagnose Then slow down, and ask for test steps instead of leads on replacement parts or instructions to remove/bypass nonfunctional systems. I will say, to some degree we, as a group, are doing you a disservice in this area as you often get batches of responses offering conflicting advice, or many seemingly unrelated tests for a single issue. This can be quite confusing to someone who is trying to learn. @squonkhas a very good point in that most of the pictures you post show electrical connection points that are in rough shape. Things like paint and corrosion are not particularly conductive. You would be well served go go through one by one and clean all the electrical connections on this tractor. 3 minutes ago, FLtractor said: 1) possibly but undiagnosed Takes one to know one. I am one, I live with three more, and I'm telling you, your post activity has all the hallmarks. 1 Share this post Link to post Share on other sites
FLtractor 208 #19 Posted 15 hours ago 2 minutes ago, adsm08 said: Then slow down, and ask for test steps instead of leads on replacement parts or instructions to remove/bypass nonfunctional systems. Mainly asking about replacement parts is an attempt to learn the cost, availability of similar reliable piece- perhaps not very good way to learn that, so should probably stop asking. I will say, to some degree we, as a group, are doing you a disservice in this area as you often get batches of responses offering conflicting advice, or many seemingly unrelated tests for a single issue. This can be quite confusing to someone who is trying to learn. Haven’t seen much confliction form what I’ve read. @squonkhas a very good point in that most of the pictures you post show electrical connection points that are in rough shape. Things like paint and corrosion are not particularly conductive. You would be well served go go through one by one and clean all the electrical connections on this tractor. Yes I need to do so. Takes one to know one. I am one, I live with three more, and I'm telling you, your post activity has all the hallmarks. Good point. could see that. Get very excited about being so close to having 856 run drive again to be put to work. Share this post Link to post Share on other sites
