Krice58
Snowblower Consensus
Krice58
What’s the consensus on the snowblowers? I have a plow already, works great but my the driveway at my new house is narrower and longer than my previous one and I don’t have room to push the snow to the sides so I figured a blower throwing it into my yard would be better. I’ve read that the single stage short chute can struggle with some of the slushy stuff and the 2 stages work well but take up more space and are much heavier. The sweet spot seems to be the single stage long chute based on what I’ve read. Any input from snowblower users? I’ll either stick it on my C160 or my 314.
ri702bill
A heavy wet overnight snowfall of six or more inches can be a challenge to clean up. I have two tractors set up for winter use - the C81 with the plow and the 854 8 speed with the 32 inch single stage snowthrower. The plow is best for moving a small amount of snow quickly; the snow thrower can move a large amount of snow rather slowly. I tend to rough out the cleanup starting with the snowthrower and finish with the plow...However, dry fluffly snow is usually dealt with the plow only - If it is windy the snow thrower shoots the snow up into the air and it usually goes everywhere but where you actually want it to go...
Edited by ri702bill
  • Excellent 5
Ed Kennell
I've used all the blowers.  Short chute, long chute, and dual stage and they all work well in the dry deep snow but not very well in the wet small snows.    The single stage blowers must be kept full to  work properly and to prevent the chute from clogging.   This means the ground speed needs to be adjusted requiring a hydro transmission.
IMO, a cab is also a must when using a blower.     I now have 48" and 54' plows on my snow movers that I use to keep five driveways clean.    I have no problems pushing and stacking the snow on the lawns.
  • Like 4
  • Excellent 2
Wayne0
I have a 2 stage on a 520H for the deep stuff (over 6 inches) and a 48" plow on a Work Horse 1800 for light snow, slush and clean up. Works good for me. 750' driveway.
As Ed said, a cab is a big plus with a blower. (I don't have one)
Edited by Wayne0
Brockport Bill
the key issue to me is the personal situation of the homeowners driveway - as well as the equipment -- i find the tractor with a blade can handle 8-10 inches comfortably - but over 10 then it makes sense to be sure to plow before it gets deeper - - especially if wet -- but clearly in your situation you have to have somewhere to put the snow -- not just for the one storm but for multiple storms over multiple weeks  -------
when i plow early in the season i always push the snow 5-6 feet off the drieway edge so i have a place to push and pile it for future storms -- but if necessary i use a walk behind blower along the edge of the driveway to throw it a distance clearing the 5-6 ft on the lawn for next storm............
- to me a modest storm of 3-4-5-6 inches is job for the blade ------ but it really depends on the driveway as much as any other factor - if as you say you dont have room and have to throw it a distance then thats a reality that cant be changed
ri702bill
I completely agree. I do the same....
I was away on business for a week years back - it snowed early in the week  & my wife paid a neighbor to plow the driveway & in back. He did not push the snow up onto the grass.... It snowed again when I got home - and had almost nowhere to put that snow.
JCM
Tough to beat a 520 - H with a cab for the big storms and clean up around the back of the shop and access to the basement. 418 or 417 with a 48'' front dozer blade is nice for the smaller amounts. C-160 and 314 will do the job as well.
  • Excellent 2
lynnmor
I put the snow on the other side of that firewood row with the 520H and 2 stage.
Of course a small amount of snow that is wet can bring things to a halt.
A glass windshield with a wiper is essential.
  • Excellent 2
pfrederi
Plow the snow into the yard. It is what I do.  I have a a 56" D series blade on a Charger 16 pushed it off ...Haven't had a need for my blower in a few years. If you have a gravel driveway get a sweepster to put the stones back in the driveway in the spring...
  • Like 4
ebinmaine
IMHO and experience...
If you need a snowblower  - get a two stage. They have the serious advantage of being able to operate at slower tractor ground speeds while having less tendency to load up.
Not none.. less.
Trina and I do basically what's outlined by several above.
Nearly all snows nowadays get the plow blade.
She absolutely loves moving snow.
We can all agree "seat time" is excellent. Here, we don't use a Wheelhorse for mowing. We do use them 4 to 5 months a year for snow removal.
We have to plan far ahead for much larger storms that don't melt.
Our plowed area is a good strong 10 to 20 feet past the desired clearing zone.
If we're home we would rather plow a large storm multiple times than use the snowblower once, then plow to scrape the surface clean.
We are currently using the Ariens Commercial walk behind snowblower.
I have a Wheelhorse Dual Stage one I'd like to try sometime. Perhaps this year and perhaps being mounted on the Briggs 20 HP Vanguard V twin powered C160-8.
  • Excellent 3
peter lena
@ebinmaine   obviousely  you are a  plow master , lots of  winter , plow and blower usage , like NAPA   MACS   chain and cable spray for any related  chain  movement , also like it on  blade faces , for much easier slide off ,  PAM  cooking  spray  also does a slick job ,  snow slider , plastic / vinyl , chute base gasket , makes for , slicker  movement , agree with over plowing  to  give me space when I can get it , let the sun  also help out , with drainage  areas . pete
ML3
Depending on your annual snowfall, driveway size, & if theres enough places to put the snow throughout the season should all be taken into consideration. Think everyone has their preferences based on their winter weather situation. I prefer to push snow with my 654 but mid winter I can run outta places to put it, even if I push as far off driveway as I can. No matter how careful I am, every spring I have to repair the damaged grass. I live in the primary snow belt so "lake effect" heavy snow events are common. My 702 w/single stage moves up to 5-6" pretty easily despite only being 7hp. This winter my HD snow removal unit will be the 416H w/2stage Bervac I bought from @Ed Kennell. Where I live a 2stage is a must have. I do also have a 2stage 26" Toro walk behind blower.
Ed Kennell
I can't wait to see this beast finally go to work.    Chuck @cafoose may want to watch.
ML3
Hoping it works this year too since last year with the Workhorse was a bust. Im kinda excited to try it
Handy Don
Long range forecasts for my area predict more of what we’ve been seeing--wet stuff amid slightly above average temps overall. Plow work.  I’ll prep the walk-behind blower anyway!
Edited by Handy Don
cafoose
Yessir :D
