JCM
1951 Farmall Super A
CRF857
I had a 1948 Cub for a few years.
 Always lusted after an A
Good looking tractor you have. 👍🤩😍
T-Mo
The A was a nice tractor, bigger and more powerful than a Cub.  They were made from 1939 to the early 1950s when it was replaced by the Super A, which is even better than the A.
You can list it here, if you're wanted to sell:
http://www.farmallcub.com/fc/
ebinmaine
12 hours ago, JCM said:
Nice to be able to see it moving again instead of it under a tarp
Lookin forward to seeing that!
JCM
Time of the Day for the STUPID questions to all you mechanical genius's out there. Why does the glass fuel bowl with brass screen and cork gasket leak. I can't remember for the past 38 years of ownership IF It ever had a rubber gasket. Will it stop the slight drip after a few day's, I have not looked at it yet today and I almost don't want to. Busy around the property getting ready for the Meet & Greet.    @953 nut   @pfrederi  @T-Mo Anyone else. Thank you Gentlemen.
T-Mo
The glass bowl will leak, either at the valve which has a seal, or the bowl itself which has a gasket on top.  The aftermarket sediment bowls are notorious for leaking at the valve.  Sometimes you have to buy a few to find one that don't leak.
JCM
Thank You @T-Mo   For the response. I will keep an eye on it to check if it stops, if not it looks like another order from Steiner Tractor.
