John c 199 #1 Posted 5 hours ago Has anybody come up with anything that will remove spray paint I mean beside an actual paint stripper. I've found another barn find on the marketplace and the hood decals have been sprayed over, I'd like to get it off if possible and save the original decal. 1 Share this post Link to post Share on other sites
ebinmaine 79,779 #2 Posted 5 hours ago We've used an orange citrus based remover that worked okay. Use caution though. A lot of the paint strippers are also quite fond of removing the decal color or basic glues. 2 Share this post Link to post Share on other sites
John c 199 #3 Posted 4 hours ago thanks, I think I've seen it in the stores before, I'll give it a try Share this post Link to post Share on other sites
Achto 32,131 #4 Posted 4 hours ago Try regular charcoal lighter fluid on a small spot. I've had good luck with it in the past. 2 Share this post Link to post Share on other sites
stevasaurus 23,761 #5 Posted 1 hour ago Acetone works great with an old rag. Read the label though...and good gloves. 1 Share this post Link to post Share on other sites
ebinmaine 79,779 #6 Posted 1 hour ago 51 minutes ago, stevasaurus said: Acetone works great with an old rag. Read the label though...and good gloves. Something I learned a few weeks ago: Acetone resistant gloves are great if handy but I don't use any. I wash my hands when done. Definitely safety glasses/ goggles. Share this post Link to post Share on other sites
WHX?? 57,486 #7 Posted 56 minutes ago 3 hours ago, Achto said: on a small spot. Yes try it on a small spot first to make sure 4 hours ago, ebinmaine said: not removing the decal color or basic glues. 1 Share this post Link to post Share on other sites
953 nut 67,630 #8 Posted 27 minutes ago 4 hours ago, ebinmaine said: also quite fond of removing the decal color or basic glues. Eric, that was my first thought, if any remover solution gets to the glue it is game over for the decal. 1 Share this post Link to post Share on other sites
sqrlgtr 3,389 #9 Posted 22 minutes ago 4 hours ago, John c said: the hood decals have been sprayed over, I'd like to get it off if possible and save the original decal I hope someone has a solution I have a couple decals that has been sprayed over also. Share this post Link to post Share on other sites
ebinmaine 79,779 #10 Posted 15 minutes ago 39 minutes ago, WHX?? said: Yes try it on a small spot first to make sure 10 minutes ago, 953 nut said: Eric, that was my first thought, if any remover solution gets to the glue it is game over for the decal. My biggest concern at first glance is/ are the cuts in the existing decals. The edges are bad enough... the cuts are curled UP so they'll be prone to inviting whatever solution is used. Share this post Link to post Share on other sites
sqrlgtr 3,389 #11 Posted 9 minutes ago I haven't tried it YET but next best thing would be removing old decal and get some new ones from @Vinylguy on here. Share this post Link to post Share on other sites
