peter lena 10,125 #1 Posted August 4 had the capacitor replaced in the central a/c unit , over 30 years in , was blowing warm air , guy was amazed at all other regular function , as stated todays units , very lucky to get half of that . planning to replace it with same model carrier , so original solid ducting can be just , hooked up . had guys from my pfizer shop help out , who also helped with original furnace , made service areas , simple easy , what a concept , this is also in the cellar ?, size of small closet , set up for service ease , and NO CIELING LEAKS , plan out , repetitive issues , do a regular , by monthly , look see , filter check , coil spray down , drainage flow discs , insure condensation discharge flow , most important ? easy, chair access , makes this very simple . recently , repainted outside condenser . always snoopin around , pete 3 Share this post Link to post Share on other sites
ri702bill 13,391 #2 Posted August 4 Maintainance on appliances, both kitchen & utility does extend their usefullness.. I drain 4 water heaters annually - my house and the rental. Ditto on giving all the expansion tanks the fingernail "Ting" test to see if they are still functional. A note on water heaters... I will NEVER buy another "self cleaning" style one ever again. It works in theory, but sucks in practice. It is self cleaning, it has a turbine blade at the bottom inside below the dip tube where the cold water comes in..... every time you draw hot water, the turbine stirs up the bottom sediment - but where does it go??? Out into everything that uses hot water. It clogs up the faucet aereators & worse, the dishwasher inlet valve screen. I could not wait for that one to die.... 2 Share this post Link to post Share on other sites
rmaynard 17,659 #3 Posted August 4 I am probably jinxing myself, but I have had a Trane XL1200 running for 37 years. It was installed in the summer of 1989. It has never been touched since. I won't let the furnace (oil) guy even look at it. I have a friend who is an A/C technician with years of experience. He says that if it is providing sufficient cooling when the temperature is 90 to 104 (as it has been this summer), don't touch it. I am currently getting bids on replacing the entire HVAC system under a little-known program through my electric provider and the State of Maryland. Since the new governor is taxing us like a crazy man, I figure that if I can get a new system for little or nothing, why not? I'll be running a sequel to this post to let you know what happens. 2 Share this post Link to post Share on other sites
peter lena 10,125 #4 Posted August 4 @rmaynard would be interested in the name of that related state set up / opportunity , i,m in connecticut with a similar nutty governor , ex , what is it classified as ? pete Share this post Link to post Share on other sites
ineedanother 2,885 #5 Posted August 4 I installed a soft start module on my 2 ton carrier unit last year for a couple reasons, one being to hopefully extend its life a bit since it is original to the house that was built in '89. I keep it clean and hope I'm not jinxing myself since it's always been a reliable unit. 2 Share this post Link to post Share on other sites
rmaynard 17,659 #6 Posted August 4 1 hour ago, peter lena said: @rmaynard would be interested in the name of that related state set up / opportunity , i,m in connecticut with a similar nutty governor , ex , what is it classified as ? pete PM sent Share this post Link to post Share on other sites
ri702bill 13,391 #7 Posted August 4 Be careful for what you wish for. Many appliances, including Central A/C's have been cost reduced so much that their life expectancy is lower that the unit it replaces. 1 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #8 Posted August 5 10 hours ago, peter lena said: had the capacitor replaced in the central a/c unit , over 30 years in , I doubt you will get 30 years out of any replacement capacitator. Actually I'd be amazed if you get 5. My AC guy says all the replacement are Chinese made even if they do have an American flag on the box. 2 Share this post Link to post Share on other sites
peter lena 10,125 #9 Posted August 5 @ri702bill todays brain fart of zero maint / any look see , only enhances breakdowns , realise , my past reflects how I look at anything , also GLAIRING TO ME ? HOW OTHERS REALLY DO NOT HAVE A CLUE ? my grandson , the welder , loves it when I give him insight to an issue , also loves pontoon kick boat fly fishing , get right after any improvement opportunity , he just went skydiving , love it , grandpa , pete 1 Share this post Link to post Share on other sites
Handy Don 17,735 #10 Posted August 5 12 hours ago, oliver2-44 said: I doubt you will get 30 years out of any replacement capacitator. Actually I'd be amazed if you get 5. My AC guy says all the replacement are Chinese made even if they do have an American flag on the box. One way to help out the central AC compressor is to add a start delay relay. This assures that it never tries to restart against residual pressure from the last cycle. It can add years to compressor motor life (including not unnecessarily taxing the start capacitor). Mine is for four minutes. My last compressor lasted over 30 years and the new unit is warrantied for 20. 2 Share this post Link to post Share on other sites
oliver2-44 11,847 #11 Posted August 5 2 hours ago, Handy Don said: One way to help out the central AC compressor is to add a start delay relay. This assures that it never tries to restart against residual pressure from the last cycle. It can add years to compressor motor life (including not unnecessarily taxing the start capacitor). Mine is for four minutes. My last compressor lasted over 30 years and the new unit is warrantied for 20. I'll look into that, Thanks 1 Share this post Link to post Share on other sites
Handy Don 17,735 #12 Posted August 5 11 minutes ago, oliver2-44 said: I'll look into that, Thanks By the way, the delay relay goes in the 24v wiring between the thermostat and the compressor control. Think of it as delaying the call for cooling before it reaches the compressor. In my system, with zone air dampers, the calling zone opens and the blower starts as normal. Only the “cold” is delayed! 😁 1 Share this post Link to post Share on other sites
