kb65
broken differantial
kb65
new issue
Broke a bolt in the differential.
this is the second time. first time was several years ago. I fixed it up with some parts i had and replaced all 4 bolts with grade 8 3/8-16 x3.5" bolts
this time the broken bolt popped a hole in the bottom of the case.
I think i may have a spare case half But may need part 2822. it is the side of the diff case.
Any one else have this issue?
  • Sad 1
pfrederi
I haven't ever broken one.  What Kind of lock nuts did you use??  If it loosens up the slop will lead to breakage.
I am now using these
  • Excellent 2
ri702bill
Welcome!
Are you using, or re-using the Eslok hexnuts in the assembly? Do not use pegular hexnuts or nylok nuts!
Just where did the bolt break - at the head, at the end of the threads?
Eslok nuts are not supposed to be reused without Loctite, as the split fingers loose their grip strength when removed and reused.
One solution - use grade 8 3/8 24 fine pitch bolts & new Eslok nuts. The threads are stronger on a fine pitch over using the coarse thread.
Very important - torque and retorque to verify the nuts are properly tightened when you assemble the diff...
Ed Kennell
Bill and Paul, just curious. Do you need to increase the recommended  torque when using the mechanical locking nuts.
pfrederi
I don't but never really thought about it:unsure:
ri702bill
I do not believe so - the torque spec for that application is for using the Eslok nuts...
kb65
this is a 2 pinion diff 4 bolts hold it together and thread into the other half no nuts.
I do have most of a 10 pinion unit. I am missing one of the side gears, 2 of the pinion gears and the snap rings that hold the axles to the side the side gears.
this is a 1276 tractor.
ri702bill
Wow! Looking at the 1276 IPM Manual, that is THE lightest duty diff design I have ever seen in a WH....
Maybe time to upgrade to a more robust design Hydro?? Not exactly cheap, but would solve the breakage issue.
Edited by ri702bill
JoeM
Yes (does WH call out this spec?)
I like using wet torque valves on lockers. Not sure if this any good but in the field I liked adding 10%. or two uga dga's
953 nut
Have you considered drilling the four threaded holes out to 3/8" and using slightly longer 3/8"-24 grade 8 bolts with flex top locking nuts.
Bill D
I think @Skipper used Grade 9 bolts to rebuild the differential on his C195.
