cleat 9,138 #26 Posted August 1 3 hours ago, rick said: Cleat, how is your project coming along? I have been busy bead blasting and painting a lot of small parts. I can't get the spray gun out to paint big parts like the hood and fender (I paint outside) because it literally either rains every day or the humidity and bugs are through the roof. 3 Share this post Link to post Share on other sites
cleat 9,138 #27 Posted August 17 Well, I had a few parts hanging around cleaned up and primed so I thought I would brave the mosquitos and paint them using my paint spray gun. I have a little less blood but at least some parts got red. 3 4 Share this post Link to post Share on other sites
peter lena 9,998 #28 Posted August 17 @Handy Don referring to that key switch / wiring set up , thats an absolute no brainer , doing an OPOSET SIDE WIRING LAY OUT . and belt drive cover AIR VENTING , would remove wiring away from trapped heat , this repetitive issue , is begging for an elimination , been using anti corrosive's on wiring connections for years , typically when I get into a repair / elimination area , I am there to ERADICATE THE PROBLEM , not replace it in kind . simple example , mule drive and mower deck bearings , MAKE AN INVISABLE CHANGE ? MAIN ISSUE , LUBRICATION FAILURE , very obvious , whining bearing noise , every related bearing on my 3 units, have been cleaned out and LUCAS X TRA HD , GREEN CHASS GREASE , HAND REPACKED , never had a related failure, also do the pto cone inner needle bearing , very lightly , grease specs 550 deg flash point , polyurea rated , anti sling , amazed with no ideas for repetitive problems , pete Share this post Link to post Share on other sites
sqrlgtr 3,646 #29 Posted August 17 1 hour ago, cleat said: paint them using my paint spray gun. @cleat is that rusto you spraying with gun and if so what kind mix ratio you useing? 1 Share this post Link to post Share on other sites
cleat 9,138 #30 Posted August 17 2 hours ago, sqrlgtr said: @cleat is that rusto you spraying with gun and if so what kind mix ratio you useing? I have been using this store brand rust paint from Home Hardware here in Canada. I just thin it using varsol until it is approximately the consistency of milk. I think around 10:1 give or take. I used the same brand primer in aerosol cans. 2 1 Share this post Link to post Share on other sites
Retired Wrencher 6,905 #31 Posted August 18 On 8/1/2026 at 3:42 PM, cleat said: I have been busy bead blasting and painting a lot of small parts. I can't get the spray gun out to paint big parts like the hood and fender (I paint outside) because it literally either rains every day or the humidity and bugs are through the roof. Cleat: It is always better paint in the early fall. I have always had good luck with this. I know you are up north weather changes fast up there. Good luck with the project. Share this post Link to post Share on other sites
cleat 9,138 #32 Posted Thursday at 08:39 PM Another rainy day do I started dismantling the engine for cleanup. I do not believe it needs a full tear down as it ran quiet and smooth. I took some picture of the tin work so I can put it back together properly. Choke and throttle linkage as found. Flywheel ready to be pulled Flywheel puller installed after chasing the threads for the puller bolts. Flywheel pulled and very dirty inside. Alternator coil is remarkably clean as compared to the flywheel for some reason. 4 Share this post Link to post Share on other sites
cleat 9,138 #33 Posted Thursday at 08:42 PM I have two fenders primed although one of them needs more sanding and a re-prime. Two hoods are stripped and ready for sand and prime. I am getting a heat pump installed in the shop so it is a mess right now. 7 Share this post Link to post Share on other sites
ebinmaine 80,143 #34 Posted Thursday at 09:57 PM 1 hour ago, cleat said: getting a heat pump installed For heat and AC? 2 Share this post Link to post Share on other sites
sqrlgtr 3,646 #35 Posted Thursday at 10:00 PM Shop with a heat pump..... You just can't hide $$$. 2 Share this post Link to post Share on other sites
ebinmaine 80,143 #36 Posted Thursday at 10:05 PM 4 minutes ago, sqrlgtr said: Shop with a heat pump..... You just can't hide $$$. I have heat and AC in the shop. Northern climate it's unavoidable. 1 Share this post Link to post Share on other sites
sqrlgtr 3,646 #37 Posted Thursday at 10:21 PM 10 minutes ago, ebinmaine said: I have heat and AC in the shop. Northern climate it's unavoidable. Very understandable I got heat but no A/C but don’t think I wouldn’t have it if I could get warden on board. Well got both in part of it but not main shop. 2 Share this post Link to post Share on other sites
cleat 9,138 #38 Posted Thursday at 11:06 PM (edited) 3 hours ago, ebinmaine said: For heat and AC? Yes, i never had AC in the shop so I am looking forward to that. I had a propane furnace but I am getting tired of paying for the tank rental and just buying propane in general. I am hoping the heat pump can keep up in the winter but if not I have a 5000 watt heater for backup. The house is getting a new heat pump with an electric air handler for air circulation and backup as well. The house central AC unit has been on the way out for a few years now and this summer the furnace blower went out and it is $1200 just for the part so I am just getting rid of the whole setup. I hope that I am not making a big mistake putting these in. I will let you know next year how they work.. These are both high seer inverter units that are supposed to be very efficient and work in the cold. Edited Friday at 01:38 AM by cleat 4 2 Share this post Link to post Share on other sites
cleat 9,138 #39 Posted Thursday at 11:07 PM 1 hour ago, sqrlgtr said: Shop with a heat pump..... You just can't hide $$$. Expensive yes but hopefully worth it in the end. 4 1 Share this post Link to post Share on other sites
cleat 9,138 #40 Posted Friday at 03:41 PM Heat pump installed just needs covers on charge lines installed. Here is the spec sheet. SB_TW24HXP2A1DITW24HXP2A1DO_20260211.pdf 5 1 Share this post Link to post Share on other sites
Handy Don 17,224 #41 Posted Friday at 04:19 PM I’m surprised that they installed the external part parallel to the wall and not perpendicular or farther out, especially with the snowfall levels in your area an possible roof shedding. You’ll have to keep an eye on the space between the unit and the wall since the unit dumps heat in the summer, but dumps cooler air in winter. 2 Share this post Link to post Share on other sites
cleat 9,138 #42 Posted Friday at 04:22 PM 1 minute ago, Handy Don said: I’m surprised that they installed the external part parallel to the wall and not perpendicular or farther out, especially with the snowfall levels in your area an possible roof shedding. You’ll have to keep an eye on the space between the unit and the wall since the unit dumps heat in the summer, but dumps cooler air in winter. Fortunately that unit is on an end wall so no snow issues that way. I will keep an eye on it but it should be fine. 2 Share this post Link to post Share on other sites
cleat 9,138 #43 Posted Saturday at 12:11 PM Flywheel has been cleaned up and painted. I screwed bolts into all 8 threaded holes to keep paint out. 3 4 Share this post Link to post Share on other sites
cleat 9,138 #44 Posted 7 hours ago Governor lever and spring as found. Governor lever and spring removed. 1 1 Share this post Link to post Share on other sites
cleat 9,138 #45 Posted 6 hours ago Governor lever as removed then de-greased. Choke and throttle lever assemblies as removed then de-greased. Choke and throttle lever assembly torn down. Choke and throttle lever assembly torn down showing new bolt and washers. 3 1 Share this post Link to post Share on other sites
sqrlgtr 3,646 #46 Posted 5 hours ago I couldn't believe how much better the governor on the 856 was after I took it off and cleaned everything up good. It was binding up on the bushing and rod that goes in the block. @cleat looks like you got a good start on this project. Love following along on these builds. 1 1 Share this post Link to post Share on other sites
cleat 9,138 #47 Posted 2 hours ago 2 hours ago, sqrlgtr said: I couldn't believe how much better the governor on the 856 was after I took it off and cleaned everything up good. It was binding up on the bushing and rod that goes in the block. @cleat looks like you got a good start on this project. Love following along on these builds. Thank you, the governor on this engine was working fine but it definitely needs a cleanup. I Will make sure nothing is binding as it goes back together. The paint on this engine is weird, thick and flaking off in spots and thin to missing in other spots. 1 Share this post Link to post Share on other sites
ebinmaine 80,143 #48 Posted 2 hours ago 6 minutes ago, cleat said: The paint on this engine is weird, thick and flaking off in spots and thin to missing in other spots. I've seen other black painted Magnums do that. Possibly they were painted during the low VOC changeover. 1 Share this post Link to post Share on other sites
sqrlgtr 3,646 #49 Posted 2 hours ago (edited) 32 minutes ago, cleat said: The paint on this engine is weird, thick and flaking off in spots and thin to missing in other spots. I have noticed that on the Magnum series a lot. @ebinmaine most have been typing the same time I was Edited 2 hours ago by sqrlgtr 1 Share this post Link to post Share on other sites
