cleat
314H cleanup and repair.
cleat
3 hours ago, rick said:
Cleat, how is your project coming along?
I have been busy bead blasting and painting a lot of small parts.
I can't get the spray gun out to paint big parts like the hood and fender (I paint outside) because it literally either rains every day or the humidity and bugs are through the roof.
  • Sad 3
cleat
Well, I had a few parts hanging around cleaned up and primed so I thought I would brave the mosquitos and paint them using my paint spray gun.
I have a little less blood but at least some parts got red.
  • Excellent 4
peter lena
@Handy Don  referring to that  key switch / wiring set up , thats an absolute no brainer , doing an OPOSET  SIDE  WIRING LAY OUT  .  and  belt drive cover AIR VENTING , would remove wiring away from trapped heat  , this repetitive issue , is begging for an elimination , been using anti corrosive's  on wiring  connections for years , typically  when I get into a repair / elimination area  , I am there to ERADICATE THE PROBLEM  , not  replace it in kind . simple example , mule drive and mower deck bearings , MAKE AN INVISABLE CHANGE ? MAIN ISSUE , LUBRICATION FAILURE , very obvious , whining  bearing noise , every related bearing  on my 3 units, have been cleaned out and LUCAS X TRA HD , GREEN CHASS GREASE , HAND REPACKED , never had a related failure, also do the pto cone inner needle bearing  , very lightly  , grease specs  550 deg flash point , polyurea rated , anti sling , amazed  with no ideas for  repetitive problems , pete
sqrlgtr
@cleat is that rusto you spraying with gun and if so what kind mix ratio you useing?
cleat
I have been using this store brand rust paint from Home Hardware here in Canada.
I just thin it using varsol until it is approximately the consistency of milk.
I think around 10:1 give or take.
I used the same brand primer in aerosol cans.
Retired Wrencher
Cleat: It is always better paint in the early fall. I have always had good luck with this. I know you are up north weather changes fast up there. Good luck with the project.
cleat
Another rainy day do I started dismantling the engine for cleanup.
I do not believe it needs a full tear down as it ran quiet and smooth.
I took some picture of the tin work so I can put it back together properly.
Choke and throttle linkage as found.
Flywheel ready to be pulled
Flywheel puller installed after chasing the threads for the puller bolts.
Flywheel pulled and very dirty inside.
Alternator coil is remarkably clean as compared to the flywheel for some reason.
  • Like 4
cleat
I have two fenders primed although one of them needs more sanding and a re-prime.
Two hoods are stripped and ready for sand and prime.
I am getting a heat pump installed in the shop so it is a mess right now.
  • Like 7
ebinmaine
For heat and AC?
sqrlgtr
Shop with a heat pump..... You just can't hide $$$.:ychain:
  • Haha 2
ebinmaine
I have heat and AC in the shop.
Northern climate it's unavoidable.
sqrlgtr
Very understandable I got heat but no A/C but don’t think I wouldn’t have it if I could get warden on board. Well got both in part of it but not main shop.
cleat
3 hours ago, ebinmaine said:
For heat and AC?
Yes, i never had AC in the shop so I am looking forward to that.
I had a propane furnace but I am getting tired of paying for the tank rental and just buying propane in general.
I am hoping the heat pump can keep up in the winter but if not I have a 5000 watt heater for backup.
The house is getting a new heat pump with an electric air handler for air circulation and backup as well.
The house central AC unit has been on the way out for a few years now and this summer the furnace blower went out and it is $1200 just for the part so I am just getting rid of the whole setup.
I hope that I am not making a big mistake putting these in.
I will let you know next year how they work..
These are both high seer inverter units that are supposed to be very efficient and work in the cold.
Edited by cleat
  • Like 4
  • Excellent 2
cleat
Expensive yes but hopefully worth it in the end.
  • Like 4
Handy Don
I’m surprised that they installed the external part parallel to the wall and not perpendicular or farther out, especially with the snowfall levels in your area an possible roof shedding. You’ll have to keep an eye on the space between the unit and the wall since the unit dumps heat in the summer, but dumps cooler air in winter.
cleat
Fortunately that unit is on an end wall so no snow issues that way.
I will keep an eye on it but it should be fine.
cleat
Flywheel has been cleaned up and painted.
I screwed bolts into all 8 threaded holes to keep paint out.
  • Excellent 3
cleat
Governor lever and spring as found.
Governor lever and spring removed.
cleat
Governor lever as removed then de-greased.
Choke and throttle lever assemblies as removed then de-greased.
122342311_Chokeandthrottleleverassembliesasremoved1.JPG.5697857d380e91b2c2206c9000aa4cde.JPG
675931456_Chokeandthrottleleverassembliesasremoved2.JPG.2ae1b648c231141ead0e9cc76eb26217.JPG
Choke and throttle lever assembly torn down.
1401632807_Chokeandthrottleleverassemblytorndown.JPG.808c50847480e0cced9f5c1c51c36727.JPG
Choke and throttle lever assembly torn down showing new bolt and washers.
898476931_Chokeandthrottleleverassemblytorndownshowingnewboltandwashers.JPG.f6bad5563bcf67364ce147425e1426e2.JPG
sqrlgtr
I couldn't believe how much better the governor on the 856 was after I took it off and cleaned everything up good. It was binding up on the bushing and rod that goes in the block. @cleat looks like you got a good start on this project. Love following along on these builds.
