MainelyWheelhorse 3,008 #1 Posted July 9 (edited) I found these knobs while looking around online. My order hasn’t been shipped yet, but we’ll see how the process goes as Carr Lane deals primarily with industrial customers. So far so good though. Not to step on anyone’s toes but I thought I’d try them out and see how it goes. Edited July 9 by MainelyWheelhorse 2 1 Share this post Link to post Share on other sites
rmaynard 17,494 #2 Posted July 9 Where will you be using these knobs? 1 Share this post Link to post Share on other sites
ri702bill 12,688 #3 Posted July 9 Looks like a Mule Drive Adjuster Knob... I have used plenty of both Carr Lane & Jergens parts over the years. They can be pricey, but excellent quality. 1 Share this post Link to post Share on other sites
rmaynard 17,494 #4 Posted July 9 Wouldn't they have to be drilled and pinned? Not that that is a problem if you have a drill press. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #5 Posted July 9 @rmaynard it’s a replacement for the knob on my mule drive for the 42” RD. The original was long gone and was tightened by using a vice grip. I’m going to have to pin it but it’s supposed to be already tapped 3/8 -16 which was the same as the stock one from the info on here. I have access to a drill press so it shouldn’t be too bad. I figured I’d find something as close as I could get. @ri702bill That’s what I’m using it for. it looks promising and at roughly 5 bucks a knob before shipping the price wasn’t too bad as well. The ordering process takes some getting used to but I have it figured out now. Good to know about the quality. I figured it being industrial it should be pretty sturdy. We’ll see how it goes. It’s not an exact match but close enough to be usable. 3 1 Share this post Link to post Share on other sites
sqrlgtr 3,581 #6 Posted July 10 4 hours ago, MainelyWheelhorse said: already tapped 3/8 -16 All the mule drive adjusting knobs I have are splined and pinned on. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #7 Posted July 10 1 hour ago, sqrlgtr said: All the mule drive adjusting knobs I have are splined and pinned on. I assumed they were threaded. There isn’t any splines inside the old brass insert on mine. I thought of tapping the end of the shaft 3/8-16, locktighting, and pinning it if need be. Share this post Link to post Share on other sites
Bar Nuthin 2,921 #8 Posted July 10 1 hour ago, sqrlgtr said: All the mule drive adjusting knobs I have are splined and pinned on. I need to pull this one off and see what kind of handy work went into making it. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #9 Posted July 10 2 minutes ago, Bar Nuthin said: I need to pull this one off and see what kind of handy work went into making it. From what I’ve seen on mine, keeping with Wheel Horses philosophy of simplicity. There’s not much to them, the knob is pinned on(at least with mine) to what looks like a fine thread bolt with the head cut off. Simple direct stuff. Easy to fix. If someone had one to take measurements from and the knowledge and access to a machine shop they wouldn’t be super difficult to reproduce. Share this post Link to post Share on other sites
sqrlgtr 3,581 #10 Posted July 10 2 hours ago, MainelyWheelhorse said: I assumed they were threaded. There isn’t any splines inside the old brass insert on mine. I thought of tapping the end of the shaft 3/8-16, locktighting, and pinning it if need be. The brass? insert that is inside the plastic knob, has a splined outside diameter. The brass or whatever its made out off insert inside bore is smooth and pinned on to the mule drive adj. bolt. I should have been more clear in my description. Still don't know how clear this description is and hope I haven't confused you . Bottom line is Ive never seen one that has threads in knob. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #11 Posted July 10 Ok, now that you phrased it that way I remember seeing the knurling/splines. Once it gets here I’ll look it over and see if I need to adapt it to work. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #12 Posted July 11 Just a heads up, my stuff shipped but I was charged 50.00 for UPS ground shipping through them. I think next time I’ll go through Amazon where they have a storefront and shipping is handled by a third party. I learned a lesson today. Share this post Link to post Share on other sites
Wayne0 1,605 #13 Posted July 11 16 minutes ago, MainelyWheelhorse said: Just a heads up, my stuff shipped but I was charged 50.00 for UPS ground shipping through them. I think next time I’ll go through Amazon where they have a storefront and shipping is handled by a third party. I learned a lesson today. OUCH! 1 Share this post Link to post Share on other sites
sqrlgtr 3,581 #14 Posted July 11 19 minutes ago, MainelyWheelhorse said: Just a heads up, my stuff shipped but I was charged 50.00 for UPS ground shipping through them. I think next time I’ll go through Amazon where they have a storefront and shipping is handled by a third party. I learned a lesson today. that stings. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #15 Posted July 11 Yeah, I was less than happy about that. Especially when there was no option to pick what you got and the shipping charge popped up only when it shipped. I emailed them to figure out why it was 4x the price it should be and basically wasted my time. I’m definitely going through Amazon next time then they might be a bit more cooperative. Share this post Link to post Share on other sites
sqrlgtr 3,581 #16 Posted July 11 14 minutes ago, MainelyWheelhorse said: I’m definitely going through Amazon next time Another option if they have what you need is Wally world. The only reason I bring this up is if you're not satisfied you can take item back to any Wally world and get a refund. Just done this with a set of tri rib front tires no fuss return, totally my fault I had ordered the wrong size.. 2 Share this post Link to post Share on other sites
ebinmaine 80,062 #17 Posted July 11 11 hours ago, MainelyWheelhorse said: charged 50.00 for UPS ground shipping Not supplying the actual shipping cost ia absolutely unacceptable and unnecessary. I'd be on the phone Monday DEMANDING a refund or canceling the order or calling my credit card company to file a fraud possibility investigation. 1 star reviews for that company too. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #18 Posted July 12 2 hours ago, ebinmaine said: Not supplying the actual shipping cost ia absolutely unacceptable and unnecessary. I'd be on the phone Monday DEMANDING a refund or canceling the order or calling my credit card company to file a fraud possibility investigation. 1 star reviews for that company too. It looks like they’re an industrial company that usually sells or distributes through a third party. It’s a possibility they weren’t set up for me to buy that. It’s a bit too late now. It’ll supposedly be here Tuesday. There’s been no charge yet except for the $9.31 for two knobs on my CC the last I knew. When the shipping charge pops up I’ll dispute it. If I deal with them again it’ll be through Amazon. It wasn’t totally bad though the CS rep I first talked to was great. Thanks for the guidance @ebinmaine. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #19 Posted July 14 I got the gold plated parts today. They are very, very, close to the original. If memory serves they are supposed to be an 1/8 smaller diameter but you can’t feel a difference. The 3/8-16 thread seems a bit small though. I’d assume they are pressed and pinned on as there are no threads on the adjustment shaft. Share this post Link to post Share on other sites
sqrlgtr 3,581 #20 Posted July 14 Yeah the original just slip on then a roll pin goes through it and the Mule Drive shaft/adjustment screw. You will have to do some careful ciphering to get the hole in the right place on the knob so it will line up with the shaft part. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #21 Posted July 16 (edited) I got it on, it’s blue locktited and the shaft is threaded 3/8-16. So far so good, it seems to be working like it should and able to spin to tighten down to hold tension. Edited July 16 by MainelyWheelhorse Share this post Link to post Share on other sites
