Thegearhead0324 1,601 #1 Posted 8 hours ago I have a quick question, looking through the forum I think I found the answer, but on my 1257, the brake drum shaft seal, would part number SKF 7410 be the correct seal? I see rock auto has one and wanted to make sure. Thank you. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,298 #2 Posted 6 hours ago Best to compare the specs against what you want to replace. Notice the CR/SKF seal numbers closely represent the shaft size. 3/4" shaft or .750" is close to the 7410 seal number. Share this post Link to post Share on other sites
702854boy 906 #3 Posted 5 hours ago SKF seal #9815 is the seal that you need for the brake drum, it is the same as the axle seals on 1 inch axles. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,298 #4 Posted 4 hours ago WH 1232 replaced by 100863 Share this post Link to post Share on other sites
ri702bill 12,330 #5 Posted 3 hours ago Best to stay away from the off-brand not-made-around-here cheap knockoffs. Unless you want to do the job over... Note the CR ad gives a Speedi-Sleeve P/N too. Great to fix a gouged up shaft. Share this post Link to post Share on other sites
Thegearhead0324 1,601 #6 Posted 3 hours ago Thank you for the replies, would anyone know of a good brand or of one that would be good to use? Share this post Link to post Share on other sites
rmaynard 17,369 #7 Posted 2 hours ago I get mine from NAPA auto parts. They are made from steel as opposed to Toro which are plastic. Share this post Link to post Share on other sites
