Thegearhead0324 1,644 #1 Posted June 26 Finally, after missing my other one I sold a few years ago, I bought one at the big show today. Looking forward to gettin it in top shape. 3 7 Share this post Link to post Share on other sites
8ntruck 9,018 #2 Posted June 26 I've always wanted one. Don't know why, 'cause it do not have a use for one. 1 4 Share this post Link to post Share on other sites
ri702bill 12,365 #3 Posted June 26 Gopher Grinder.... 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #4 Posted June 26 I haven’t had any use for one but it’s always been that “one piece” that I’ve been missing since I sold my other one like a fool. Share this post Link to post Share on other sites
adsm08 4,735 #5 Posted June 27 I don't even know what they are good for. Share this post Link to post Share on other sites
8ntruck 9,018 #6 Posted June 27 I've got a ditch on my Ky. property where a sickle mower that could angle down would be really handy - except for the rocks that are in the ditch..... 1 Share this post Link to post Share on other sites
Racinbob 13,016 #7 Posted June 27 I had one for 20-25 years before the move to Florida in 2000 when it was sold in the auction. After coming back up here in 2017 I started looking for another one. Finally, after running an ad, I found one less than 15 miles from here. A guy bought it in an auction and after realizing seeing that it was so rusted solid he must have figured it was unsavable. I didn't see it that way. Here's the thread. Sickle Bar Finally - Implements and Attachments - RedSquare Wheel Horse Forum 8 hours ago, adsm08 said: I don't even know what they are good for. If ya need one you'll know. Mine runs at about a 45° angle about 90% of the time. I keep the briars that intrude on the paths out back clear. 7 hours ago, 8ntruck said: I've got a ditch on my Ky. property where a sickle mower that could angle down would be really handy - except for the rocks that are in the ditch..... The Wheel Horse model doesn't angle down but a very few degrees. I've heard the Haban will go more but I can't verify. 2 2 Share this post Link to post Share on other sites
gt14rider 1,223 #8 Posted June 27 Haban 414 for GT14. 3 1 Share this post Link to post Share on other sites
sqrlgtr 3,143 #9 Posted June 27 Sickle mower has been on my bucket list for at least 20yrs now but just haven't been able to connect with one. @cafoose has one and its the only one Ive eve seen in the wild around here. Wished he would hurry up and get bored with it and pass it on to me. 2 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #10 Posted June 27 Here’s a better pic of it, when I get time I’ll be starting on it. 2 1 Share this post Link to post Share on other sites
peter lena 9,928 #11 Posted June 28 @Thegearhead0324 would love to go thru one of those . massive example OF COLLECTIVE DRAG , every stage is another handoff . typically starts with pto lever , needle cone bearing drag , that hi heat intense , spot , cooks regular grease , black , cracking debris shows you that , lucas x tra hd green chassis grease , after a total bearing clean out , 550 deg flash point , polyurea , none of my bearings squeal / or whine , every stage , needs to be , verified / enhanced for movement ease . when I pull back on my pto lever , the spindle spins down on its own , what is that showing you for movement ease ? never wore out a clutch disc . experiment / try . test / try . pete 2 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #12 Posted June 28 @peter lena , my tractor is all lubed/greased up. My other sickle I sold a few years back I stripped and painted, greased all points, etc. Fluid film is my favorite lubricant and undercoating, I use it yearly on my vehicles and other things. On this one, everything seems to move freely and nothing is seized. I’m going to keep its original look and just clean it up real good, check inside the wobble box, and grease it up, new belts, etc. 2 Share this post Link to post Share on other sites
peter lena 9,928 #13 Posted June 28 @Thegearhead0324 if any of that is too intense for you ? try SOMETHING on a smaller scale , to inspire / encourage you , i,m on the other end of this , been doing this for decades , ex ever add a pull spring to a choke / throttle end lever point ? that lubricated slide is always smooth easy . spring pull assist TO CLOSE , POINT . that way any of your throttle INCREASE , is lightly spring pull assisted , make the penetrating oil run / drip out of the end spring pull point , also touch up any related linkage movement spots . all of mine are free and easily move , most of the stuff I see is faded rust , so easy to start a reversal of that . pete 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #14 Posted July 1 While the warden took an overnight trip to Buffalo, I made a bit of progress on the unit. I took it apart, gently washed all the pieces with soap and water, then rubbed in my favorite juice and keeping its “patina.” Greased and lubed what was needed, and started putting it back together. It has all the original decals in good shape. 2 Share this post Link to post Share on other sites
peter lena 9,928 #15 Posted July 1 @Thegearhead0324 had to put on a bib , was having a lubrication meltdown ! a regular for me , is to clean out and ENHANCE EVERY RELATED BEARING , WITH LUCAS X TRA HD GREEN CCHASSIS GREASE , specs are awesome for trouble / failure areas . 550 deg flash point , polyurea rated , every pulley , movement point , will actually move with ease , DETAIL , MAKE SURE YOU CLEAN OUT AND LIGHTLY REGREASE THE PTO CONE INNER NEEDLE BEARING ? typically dry / cooked used to be grease , is like a drum brake on your initial lever engagement , ? once you try that , you will want to enhance every / any movement spot . every bearing stage I have has this improvement , years in , no whyining noise or failures , more than worth a try, , dare to experiment , walmart $ 8 , never burned out a clutch disc , what does that tell you about drag reduction ? doing a good job , sending you good ju ju . pete 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #16 Posted 13 hours ago Here’s the ol 1257 with the 1311 50” sickle bar. The assembly has original decals and original “patina” paint. Works as it should. It has a “new old stock” wheel horse belt I put on it. Everything’s lubed, 30 weight oil in the wobble box, etc. 4 Share this post Link to post Share on other sites
c-series don 12,042 #17 Posted 11 hours ago On 6/26/2026 at 6:31 PM, 8ntruck said: I've always wanted one. Don't know why, 'cause it do not have a use for one. I have one, don’t know why ‘cause I do not have a use for one! I guess I bought it for the coolness/rarity factor! 1 1 Share this post Link to post Share on other sites
WHX?? 57,270 #18 Posted 11 hours ago (edited) WOW not enough Edited 2 hours ago by WHX?? Share this post Link to post Share on other sites
WHX?? 57,270 #19 Posted 11 hours ago 1 minute ago, c-series don said: I have one, going to sell it to WHX when he comes picks up a planter don’t know why ‘cause I do not have a use for one! There fixed that for ya ... 1 1 Share this post Link to post Share on other sites
c-series don 12,042 #20 Posted 11 hours ago Planter AND the sickle bar? That might be too much for you Jimbo🤣🤣🤣🤣 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #21 Posted 4 hours ago @c-series don Same for me, I have no need for one right now. I had one prior and sold it, regretted it. Couple years later I saw this one for sale and picked it up at the big show couple weeks ago. My old one was beat up so had to repaint it and replace parts. This one I just stripped apart, cleaned, wiped down and greased up with new belts. 1 Share this post Link to post Share on other sites
sqrlgtr 3,143 #22 Posted 1 hour ago 2 hours ago, Thegearhead0324 said: I have no need for one right now. If you get to thinking someone that needs should have it I will gladly come and get it if you will split the fuel bill with me 1 Share this post Link to post Share on other sites
Thegearhead0324 1,644 #23 Posted 1 hour ago 4 minutes ago, sqrlgtr said: If you get to thinking someone that needs should have it I will gladly come and get it if you will split the fuel bill with me Someday me and the warden will afford a nice piece of land to enjoy and I’ll be out there with a smile just “sickling” around and pretending not to hear her yelling to me to come inside. 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,143 #24 Posted 1 hour ago 1 minute ago, Thegearhead0324 said: me and the warden Dont you get to feeling special I got one of them to….. 1 Share this post Link to post Share on other sites
c-series don 12,042 #25 Posted 58 minutes ago 6 minutes ago, Thegearhead0324 said: Someday me and the warden will afford a nice piece of land to enjoy and I’ll be out there with a smile just “sickling” around and pretending not to hear her yelling to me to come inside. I honestly could not have said it better myself! That’s exactly what I’m thinking!! I’ve said it before here, sometimes when I see a wheat or hay field I think to myself “ I’d like to cut that with my sickle bar!” Then I think about all the sneezing and itchy watery eyes I’d have! And by the way, “sickling around” really cracks me up! 2 Share this post Link to post Share on other sites
