rwlvt
36 inch tiller: What am I in for?
rwlvt
Posted (edited)
Hi folks,
I'm at it again, and as usual, I'm out of my depth.  This time, I have just installed an old 36 inch tiller.
spacer.pngtiller800.jpg.ec24fca4d14b607823a6464443842e34.jpgspacer.pngspacer.pngspacer.png
Model is unknown, but this has to be an 80's or 90's vintage.  It has a Wheel Horse label, though the model and serial number are illegible.
After some research, fussing, and a few miscellaneous pins and springs, I got the thing together this morning, and it was working!!!
Unfortunately, I think I BROKE it.   😒
Admittedly, I'm trying to till a rough patch of ground, and I'm new to the machine.  I thought I got the feel of it. I put the tiller in the ground and let it till for a bit before moving ahead a foot or so.  But ultimately, it stopped working.  I am intimately familiar with the belt assembly at this point.  It's not the belt or the assembly.  The PTO is working, the large pully on the tiller is turning, the shaft is turning, but the tines are not.
So, my question to you Wheel Horse guru's is:  What am I in for?  Getting this thing on was a chore.  The prospect of taking it off is not pleasant, but it seems like I'm going to have to get into the gear box.  Any advice before I disassemble?
Thanks in advance,
Ron
Edited by rwlvt
punctuation
kpinnc
I think the Wheel Horse tiller is one of the best implements they ever built. They can be hard to work on but are mechanically simple.
The tiller gearbox just has two sprockets and a heavy chain. Sounds like it skipped off one sprocket or the chain broke.
Either way, you gotta open it and have a look. Good time to inspect the bearings and seals and replace as needed. The case holds about a quart plus of oil as well.
The difficult part is always removing the tines from the center shaft. Each tine set use a couple pins to hold them on the center shaft but it is not uncommon for the tines to brown weld onto the shaft. Lots of heat and penetrating oil are sometimes required to break them loose.
Skwerl58
I was into mine after it locked up a couple of months ago. Like kpinnc stated the hard part was getting the tines removed. I cleaned them then shot pb blast at each point I could see the shaft. Turned it up sideways and shot it between the tines and shaft also while tapping them with a hammer. With a lot of persuasion they came off. You will need a new case gasket or heavy duty gasket maker and possibly shaft seals also. A vendor here has the gasket and seals. I used a wood block to help separate the case because it is cast and you could crack it if you hammer on it. They are simple but take pictures along the way to help with reassembly. Mine held about 28 ounces of 85-140 gear lube. Hope you get it going because they are a great implement.
rwlvt
Hoo boy!  That's pretty much what I thought, but thanks for the insights.
rwlvt
There are several tiller models in this likely time frame.  This one definitely has the Wheel Horse label.  They all look pretty similar.  Any idea whether the gasket and seals are likely the same for several models?  Or any clues about how to determine exactly which model I have?
gwest_ca
All the tillers for this application are listed here. Click on the picture in the link.
oliver2-44
if you figured out how to install the tiller and belt drive, the gearbox won't be hard for you.
rwlvt
Well, the shell and the tines are off.  It turns out the most difficult thing so far is removing this pulley...
So far, heat, tapping, and pulley puller have failed.  Looks like a clip on the outside but I don't have a clue how to remove it.  Any suggestions?
rwlvt
Posted (edited)
Yes, I removed the retaining bolts (set screws) on the other side.
Edited by rwlvt
pfrederi
Is there a set screw on the backside of the pulley  #54 grips key #53
rwlvt
Persistence paid off--though it cost me a pulley.  (I suspect some of you knew this would be the case.)  😏
I checked around before pulling it and found reasonable replacements before I did too much damage...705002070_PXL_20260626_134150225(Webpage).jpg.c7ed3e3fca4f90f206a8112030ca7098.jpg
That allowed me to remove the remaining bolts and gingerly separate the sides of the casing...  551181575_PXL_20260626_140743797(Webpage).jpg.5fa943077eca65b88311d8e7b49f46be.jpg
Finally got the case apart, and indeed, the chain was broken. 13330646_PXL_20260626_141759040(Webpage).jpg.f96f4271361f45f3b1cf968985e058a8.jpg
That seems like the best possible outcome.
Other broken parts look like they would be more difficult to repair.360294353_PXL_20260626_141724667(Webpage).jpg.936e760b468ee721d1cc25c9f32a9855.jpg
So, I'm hoping I will be able to repair the chain.  Clearly, I will need a new gasket  and probably new seals.  Any other thoughts?
Also, tell me if this is too much information.  Just sharing my experience in case it might help another newbie.  😁
  • Excellent 2
ineedanother
Nicely done! Gasket, seals, and just a couple other things I would consider at this point...those cases rarely need oil but I would pull both plugs and get some anti-sieze on the threads. The other thing which you've maybe already done is check the gears and chain really well while it's in your hands. That link broke for a reason and others might be headed in that direction. Teeth on the gears can be "massaged" with a dremel or file if needed and when you find the right chain you can make the call on how extensive the repair needs to be.
rwlvt
It's been  weeks, but I'm finally getting to re-assembling this tiller.  Got things cleaned up pretty well.  I looked at the tine shaft this morning and saw some wear in the teeth of the gear.
 1776155653_PXL_20260725_143609228.MP(Webpage).jpg.5c6f05797b51c8f9876bc24fd9242336.jpg
This probabaly wouldn't bother much but since I have it apart, I ground down anything that felt sharp or too badly deformed.  Here's the result...1984627161_PXL_20260725_143832633(Webpage).jpg.2b1087090100300407a668ab4a3e5f75.jpg   1716611747_PXL_20260725_150212947.MP(Webpage).jpg.84b188bbb74ed27739f57a770f7effac.jpg
The bearings all looked good.  I did replace the oil seals and started re-assembly.  All bearings and seals are pretty heavily greased.
The tiller failed because the chain was broken.  So, I bought a new chain and cut it to size rather than fixing the old one...
I just laid the gasket on there to make sure it would work.  Thankfully, it seems like the right fit.  I plan to use some gasket sealer as well.
The other side of the case is cleaned up and ready to go.
1281747373_PXL_20260725_214437215(Webpage).jpg.d3aeec61901f92adefa72cc3aae6e6ce.jpg   435058045_PXL_20260725_214448712(Webpage).jpg.8705b4884201adc811614c51d23e6cff.jpg
A couple of questions. In the closeup of the pulley shaft above, there is a new bearing that was not in the original machine.  When I orders new washers, it came as a set with this bearing.  I take it this was on newer models.  It is not in the drawing.  It definitely doesn't go on the underside.  That causes to gears to misalign too much.  Not sure if it's going to fit, but I'll give it a try here.
The reason I ordered these washers was because one was actually BROKEN in the case.
I also found a broken circular clip in the case when I pulled it apart.  The circular clips are on the tine shaft.  They hold the washers on that shaft away from the gear and chain.  They're in place.  So, I assumed that it was for the 3/4 inch pulley shaft.  But there is no place for it that I can see.  Any thoughts from anyone who has torn one of these apart?
Any other thoughts before I close this thing up would be appreciated.
Thanks all for being here.
Ron
ineedanother
Looks great. If this is the bearing in question that wasn't there previously, my opinion is that it doesn't belong. That would be the wrong bearing for that application :confusion-shrug:.
rwlvt
Yeah...I'm not sure about it.  If it IS used, it will ride up against this surface in the opposite side of the case...
Ultimately, unless I get other feedback, I planned to test the fit when I close the case.  Behind it is the replacement washer.  The original washer, I mentioned, was broken inside the case when I pulled it apart.  Something caused that.  It seems very unusual that a washer would break.  I ordered parts based on the part #s in the diagram, so I assumed it was part of the assembly.
I dunno...  Without more information, I'm operating on the premise that it shouldn't hurt and it might help.  Thanks, though ineedanother, for the feedback.
rwlvt
Well, I was hoping to close this thread out.  This has been a summer of fixing stuff.  I've put off testing the tiller for other priorities; but if I'm honest, I don't want to find out that my efforts were wasted.  We've had unusually warm November weather for Vermont, and I finally got the tiller on the tractor for its maiden voyage.
I destroyed the old "input" (term from one of the manuals) pulley, getting it off the shaft.  I won't go into detail, but it did not come off willingly.  You can see it in some of the photos above.  I might regret this, but I replaced it with a similar pully spec'd for an air circulator.  This after much searching around, not finding an exact replacement, and I don't really like the original anyway...because I destroyed it trying to get it off!  🫤  I can get a pulley puller on this one, and I think this pulley will hold up to the stress of this application.  (Actually, I already did put a pulley puller on there when I found that it didn't quite line up with the idler pulley in front of it.)  It was also a fraction of the cost of other steel pulleys.
The only thing is that it's a 9 inch pulley.  The original was 9 1/2 inches.  A little math tells me that the belt length should be about an inch shorter.  The current belt is 138 inches (outside), and it is indeed a little loose.
And...as feared...my first run was not successful.
The belt turns the tiller, but slips off as soon as there is any resistance.  So, I guess I'm ordering a new belt.  I'm thinking 137 inches, but would appreciate some feedback on how much tension should be on the belt.  I'm also missing the belt guard for the front, but I don't think that is critical.
Anyway, I appreciate the feedback I have here, and thought that the pictures might help someone else.
Thanks to you all.  Let me know your thoughts.
c-series don
I’d say get the shorter belt and use it! That spring you have should supply adequate tension on the belt. As @kpinnc said the rototiller Wheel Horse made was one of the best attachments they built. I’m on my third set of tines over the course of 40+ years In fact I have two tillers, not even sure why?🤣🤣🤣
rick
@c-series don, where did you find replacement tines for a WH 36 inch tiller?
TIA
rwlvt
New belt is already on order.  B)
c-series don
@rick I bought them probably 20 years ago from a dealer. If I remember correctly they were about $350 back then. I bought another tiller cheap that leaked oil like crazy, but the tines were like brand new. I have since split it and resealed and regasketed it, now I have two!!
Brockport Bill
one of first awesome photos i saw on RdSq was 3-4 years ago Don was one of your tractors with tiller working in a fairly large garden - - really spoke volumes about what these tractors were built to do ----------- i used my tiller on my 1989 WH 312-8 to put in my lawn on a 1/2 acre lot over 40 years ago -- plus a few gardens tilled over the years - the one caution i will volunteer is they require patience and low gear slow if trying to cut into hard packed ground or turf -- -- However, turning over an existing garden is like butter ------------- as a commentary of the various WH models we all love, I must admit that 12 hp Kohler with that tranny NEVER lacked for power or torque to do any project. I've pulled the wh rolller up hills and plowed some serious snow as well as tilling and the 312 always handled it easily -- i mostly use a C165 twin now as my worker but that 312 aside from being my nostaglic "first w.h." will always be my favorite - no wonder so many 312's were sold -- they are reliable beasts for tilling or whatever task.
  • Excellent 2
rwlvt
The body of my tractor shows 314-8, but the engine is from a 312.  I've cut a lot of trees on the property over the years, but one large tree fell 90 degrees from my intended direction--right on my 312-8.  It smashed the hood, steering wheel.  The engine cowling was severely dented, but the engine was otherwise intact.  The cowling is actually part of the ignition system so I had to repair it.
I pulled the cowling.  Pounded it back into reasonable shape. Put it back on...and the engine fired right up! :happy-bouncymulticolor:
I found the 314 chassis without an engine and kept the 12-horse.
  • Confused 1
  • Similar Content
    • andrewLL
      By andrewLL
      Hi
      I have recently bought a cheap old gearbox mainly for the cast hubs that the wheels bolt to, then I thought as it turns a little but can't change gear or anything like that it would be interesting to look inside!!  Do they all look like this?  Can it be brought back to life?  It's now soaking in a tub of paraffin to see if it will clean up.  It's a 4 speed with high and low ratios with a 1 1/8" axle, I think I read somewhere that there are two sizes of axle.  Any thoughts?
      Andrew
