Wayne0 1,634 #1 Posted May 29 (edited) My Workhorse 1800 seems to have given up the ghost.This is my worker, and it works hard. Hard starting, back fires out the exhaust when trying to start, when it starts. Not into a rebuild. (I do know it ran out of oil once) Thinking of a Vanguard swap. How easy? or not. I know someone here has done it. Edited May 29 by Wayne0 Share this post Link to post Share on other sites
kpinnc 18,940 #3 Posted May 29 1 hour ago, Wayne0 said: Thinking of a Vanguard swap. How easy? or not. I know someone here has done it. Several of us have done this swap. And Vanguard 12.5 to 23 hp horizontal shaft engines are all very similar. Electrical- since your WorkHorse had magneto ignition the wiring is easy. Vanguards are magneto ignition so no changes there. Mechanical- check the PTO shaft on your engine. It should be 1 inch diameter and about 3 inches long. Again, exactly the same as a Vanguard. Also the PTO brackets bolt right up on a Vanguard. Engine mounting- This is primarily the part you'll need to do some work. I had to fabricate a mount plate to raise the engine about 1 inch higher and the bolt pattern is not the same. In short you will need to fab up an adapter but it is a simple job. The complexity is really up to you and what you can make up. Flip through the threads below and there are pics of some of mine. Hopefully others will chime in as well. 523-H build Another Fronkenstein 1 6 Share this post Link to post Share on other sites
Wayne0 1,634 #4 Posted May 29 (edited) @kpinnc Thanks for that info! Now I have to find one and I don't know the the text is red! Edited May 29 by Wayne0 1 2 Share this post Link to post Share on other sites
ebinmaine 80,657 #5 Posted May 30 14 hours ago, kpinnc said: Engine mounting- This is primarily the part you'll need to do some work. I had to fabricate a mount plate to raise the engine about 1 inch higher and the bolt pattern is not the same. In short you will need to fab up an adapter but it is a simple job. The complexity is really up to you and what you can make up. The mount needs to be a solid top plate per the Briggs manual. Just a stack of washers or a set of 4 spacers won't support the aluminum block well enough. 1 1 Share this post Link to post Share on other sites
kpinnc 18,940 #6 Posted May 30 4 hours ago, ebinmaine said: The mount needs to be a solid top plate per the Briggs manual. Just a stack of washers or a set of 4 spacers won't support the aluminum block well enough. This is true. Thanks for the reminder! 1 Share this post Link to post Share on other sites
Wayne0 1,634 #7 Posted May 31 I think I may have jumped the gun on this. Once it starts it runs fine. It might be a simple fuel problem. I'll clean the carb and see what happens. 1 Share this post Link to post Share on other sites
ebinmaine 80,657 #8 Posted May 31 1 minute ago, Wayne0 said: I think I may have jumped the gun on this. Once it starts it runs fine. It might be a simple fuel problem. I'll clean the carb and see what happens. Clean the fuel pump too. Those are a known issue. Share this post Link to post Share on other sites
Wayne0 1,634 #9 Posted May 31 4 hours ago, ebinmaine said: Clean the fuel pump too. Those are a known issue. I have a Carbole to put on it. 2 Share this post Link to post Share on other sites
peter lena 10,048 #10 Posted May 31 @ WayneO , harbour freight has them in stock , been using carbole low pressure 2 - 3,5 PSI pumps for years , no issues at all . have many hours on n them , makes for a good swap , been using valvoline vr1 10-30 oil , after this winter , cold start spin up was ridiculously fast smooth / easy , regularly experiment with ideas , love a repetitive problem ? dissect it make it better / eliminate it . good project , pete Share this post Link to post Share on other sites
sqrlgtr 3,868 #11 Posted May 31 25 minutes ago, peter lena said: valvoline vr1 Ive been running this in my VW buggy and really like it. I think it's hard to beat in a soild lifter motor. I would run it in my Kohlers to, but the Rotella 30wt is just easier for me to find. The Valvoline has a little more zinc in it than the Rotella. 1 Share this post Link to post Share on other sites
peter lena 10,048 #12 Posted May 31 @sqrlgtr thanks for the reply , been adding rislone zinc to my engines for years , on rotella , bottle spec , 4 oz for 2 qts , the varnish cutting effect of zinc , really helps clean up and break down deposits , none of my engines smoke or use oil . get mine at walmart , my engines really feel free and easy running , like trying things , always make it function easier . engines , are very happy at their work , pete Share this post Link to post Share on other sites
Bill D 3,142 #13 Posted June 1 (edited) 9 hours ago, Wayne0 said: I think I may have jumped the gun on this. Once it starts it runs fine. It might be a simple fuel problem. I'll clean the carb and see what happens. The fuel pump is built into the carb on those engines, if it's original. Some variations from Craftsman tractors used a carb without an integrated fuel pump. Electric external fuel pumps won't work. Rebuild the carb and fuel pump. New fuel line and filter and see what happens. Backfiring could be caused by bad plugs or a coil that's failing. Edited June 1 by Bill D Share this post Link to post Share on other sites
kpinnc 18,940 #14 Posted June 1 29 minutes ago, Bill D said: Backfiring could be caused by bad plugs or a coil that's failing. Or a many years old muffler with alot of carbon buildup in it. 5 hours ago, Wayne0 said: I have a Carbole to put on it. I have 4 tractors with these on them. They all work well! As a matter of fact, Vanguards can get twitchy with a pulse pump. Using an electric on them is much better. Just food for thought if you go that route. Share this post Link to post Share on other sites
Wayne0 1,634 #15 Posted June 1 (edited) 12 hours ago, Bill D said: The fuel pump is built into the carb on those engines, if it's original. Some variations from Craftsman tractors used a carb without an integrated fuel pump. Electric external fuel pumps won't work. Rebuild the carb and fuel pump. New fuel line and filter and see what happens. Backfiring could be caused by bad plugs or a coil that's failing. I rebuilt the pump about 15 years ago, so I'm sure it could use it again. If I can't use the electric pump on the Briggs, I'll put it on the 520H. Edited June 1 by Wayne0 Share this post Link to post Share on other sites
Bill D 3,142 #16 Posted June 1 1 hour ago, Wayne0 said: I rebuilt the pump about 15 years ago, so I'm sure it could use it again. If I can't use the electric pump on the Briggs, I'll put it on the 520H. Was it damp out the day it was backfiring? I've seen leaking plug wires cause issues. The way they are routed on the Briggs makes this even more likely to cause problems if they are old. Share this post Link to post Share on other sites
Wayne0 1,634 #17 Posted June 1 8 hours ago, Bill D said: Was it damp out the day it was backfiring? I've seen leaking plug wires cause issues. The way they are routed on the Briggs makes this even more likely to cause problems if they are old. Thanks, it wasn't damp but I'll check those too. Share this post Link to post Share on other sites
Wayne0 1,634 #18 Posted August 6 (edited) Bringing back an older thread. The motor is blowing out the carb and crank case vents big time. I'm sure it's toast. IF i DO get it started, it dies as soon as I put it under load. I have a line on a v-twin kinda local for reasonable $. Looks like a Vanguard, but with out the name. Edited August 6 by Wayne0 2 Share this post Link to post Share on other sites
ebinmaine 80,657 #19 Posted August 6 5 minutes ago, Wayne0 said: I have a line on a v-twin kinda local for reasonable $. Looks like a Vanguard, but with out the name. Interesting. What's it outta? Share this post Link to post Share on other sites
Wayne0 1,634 #20 Posted August 6 1 hour ago, ebinmaine said: Interesting. What's it outta? He said it was a Vanguard. @Echosoul has it. Connecticut, so it's not far. 1 Share this post Link to post Share on other sites
Handy Don 17,466 #21 Posted August 6 1 hour ago, Wayne0 said: Definitely a clone. You’ll want to confirm the maker and availability of parts, Share this post Link to post Share on other sites
Bill D 3,142 #22 Posted August 7 17 hours ago, Wayne0 said: Bringing back an older thread. The motor is blowing out the carb and crank case vents big time. I'm sure it's toast. IF i DO get it started, it dies as soon as I put it under load. I have a line on a v-twin kinda local for reasonable $. Looks like a Vanguard, but with out the name. If you want to stick with the boxer twin I have one I could let go of. PM me if interested. There's also one in Bristol CT on Marketplace and NOS ones on ebay. Personally I like the Briggs opposed twins. 1 Share this post Link to post Share on other sites
kpinnc 18,940 #23 Posted August 8 On 8/6/2026 at 6:43 PM, Handy Don said: Definitely a clone. You’ll want to confirm the maker and availability of parts, Look right to me. That's a big Vanguard, likely 21 or 23hp. The tins and double barrel intake manifold are just like my 23hp. I swapped the same flywheel screen for a recoil starter. Then I found out how hard it is to pull start a 23hp engine... The carb on mine cost more than the engine. Finding one that isn't for a vertical configuration is difficult. But they are still out there. 2 1 Share this post Link to post Share on other sites
953 nut 69,175 #24 Posted August 8 8 hours ago, kpinnc said: Finding one that isn't for a vertical configuration is difficult. Time to design an adaptor and have them 3-D printed, you could corner the market and get rich! Well, maybe cover expenses. 2 Share this post Link to post Share on other sites
kpinnc 18,940 #25 Posted August 8 7 hours ago, 953 nut said: Time to design an adaptor and have them 3-D printed, you could corner the market and get rich! Well, maybe cover expenses. The big thing is the tab on the throttle shaft. So long as it is oriented correctly, then all you need is the proper adapter to set the carb in the right position. 1 Share this post Link to post Share on other sites
