FarmallFarmer09 19 #1 Posted 5 hours ago Just picked up a fresh sheet of stickers for my charger 12. Whats the best way to apply them ive heard soapy water and squeegee it out or just stick em on there, what do yall recommend? Share this post Link to post Share on other sites
ri702bill 11,952 #2 Posted 3 hours ago If you bought them from Terry - @Vinylguy - why not ask him what he recommends..... Share this post Link to post Share on other sites
FarmallFarmer09 19 #3 Posted 3 hours ago Bought them from maple hunter decals Share this post Link to post Share on other sites
JCM 11,135 #4 Posted 2 hours ago Spray the CLEAN surface liberally with Non - Ammonia Windex . apply the decal and remove all the air bubbles from between surface and decal. Share this post Link to post Share on other sites
c-series don 11,859 #5 Posted 1 hour ago DO NOT try to put them on without soapy water or using @JCM’s recommendations. A credit card works good to squeeze out the air bubbles and excess soapy water. Putting them on wet allows you to move the decal around to the exact spot you want it. Share this post Link to post Share on other sites
Bar Nuthin 2,349 #6 Posted 1 hour ago (edited) If they're going over a fresh paint job, it's important to sand any dust nibs out of the paint with some fine wet-sand paper (like 1000 grit). I applied my neighbor's decals dry, but I have 50 years of bodywork experience. If you're not sure, use the soapy water (just a little soap in a spray bottle of water) technique with a squeegee (use a squeegee wet or dry). Also helps if you keep your fingers wet when handling the decal. I've installed my share of Trans Am chickens! A clean smooth surface is the #1 priority. Edited 46 minutes ago by Bar Nuthin 1 Share this post Link to post Share on other sites
sqrlgtr 2,703 #7 Posted 35 minutes ago the last ones I installed where for an 857 and I didn't use any soapy water. They were the same size hood decals @Bar Nuthin has pictured above. Had no problems but can see how the soapy water would help if you got in trouble applying them and had to readjust your decal.. They came from @Vinylguy (a sponsor here) and I highly recommend him. 2 Share this post Link to post Share on other sites
WHX?? 56,251 #8 Posted 17 minutes ago Those guys are full of it ... best way to put them on is order two sets. Take the first set and crumble them up and toss them. Take the second set and give them to @Achto and pay him to be your friend and he'll put them on ... 1 Share this post Link to post Share on other sites
