FarmallFarmer09 22 #1 Posted May 4 Just picked up a fresh sheet of stickers for my charger 12. Whats the best way to apply them ive heard soapy water and squeegee it out or just stick em on there, what do yall recommend? 2 Share this post Link to post Share on other sites
ri702bill 12,274 #2 Posted May 4 If you bought them from Terry - @Vinylguy - why not ask him what he recommends..... 2 Share this post Link to post Share on other sites
FarmallFarmer09 22 #3 Posted May 4 Bought them from maple hunter decals 1 Share this post Link to post Share on other sites
JCM 11,187 #4 Posted May 5 Spray the CLEAN surface liberally with Non - Ammonia Windex . apply the decal and remove all the air bubbles from between surface and decal. 5 Share this post Link to post Share on other sites
c-series don 11,993 #5 Posted May 5 DO NOT try to put them on without soapy water or using @JCM’s recommendations. A credit card works good to squeeze out the air bubbles and excess soapy water. Putting them on wet allows you to move the decal around to the exact spot you want it. 3 3 Share this post Link to post Share on other sites
Bar Nuthin 2,523 #6 Posted May 5 (edited) If they're going over a fresh paint job, it's important to sand any dust nibs out of the paint with some fine wet-sand paper (like 1000 grit). I applied my neighbor's decals dry, but I have 50 years of bodywork experience. If you're not sure, use the soapy water (just a little soap in a spray bottle of water) technique with a squeegee (use a squeegee wet or dry). Also helps if you keep your fingers wet when handling the decal. I've installed my share of Trans Am chickens! A clean smooth surface is the #1 priority. Edited May 5 by Bar Nuthin 4 4 Share this post Link to post Share on other sites
sqrlgtr 3,041 #7 Posted May 5 the last ones I installed where for an 857 and I didn't use any soapy water. They were the same size hood decals @Bar Nuthin has pictured above. Had no problems but can see how the soapy water would help if you got in trouble applying them and had to readjust your decal.. They came from @Vinylguy (a sponsor here) and I highly recommend him. 4 Share this post Link to post Share on other sites
WHX?? 56,916 #8 Posted May 5 Those guys are full of it ... best way to put them on is order two sets. Take the first set and crumble them up and toss them. Take the second set and give them to @Achto and pay him to be your friend and he'll put them on ... 2 11 Share this post Link to post Share on other sites
wallfish 20,062 #9 Posted May 5 Clean Clean Clean the area with rubbing alcohol. You can't clean it too much Position the decal leaving the paper on the back. Use painter's masking tape on the longer top side to hold it in perfect position. Now it can't move and keeps them from sliding. Flip up the decal that's hinged by the tape, spray the entire area with Windex ( When it dries it doesn't leave any soap residue behind.) Remove paper backing and carefully roll the decal back down and squeegee any air bubbles and Windex out. Squeegee from the center out to the edges on large decals but WH decals are small. Then remove the tape and protective cover paper. Rub the decals with a soft rag pushing down to ensure every possible area and the edges adhered well. You can probably find some good videos on youtube. We used to do car decals, lettering and pin strips for car dealers professionally back in the day. Think of those big Firebird decals on the hoods. Also did my own van lettering quite a few times. 4 2 Share this post Link to post Share on other sites
kpinnc 18,521 #10 Posted May 5 I spray both the surface and the back of the decals with Windex. This allows you to move the decal around very easily. And if it starts to grab, peel it back and spray it again. The Windex evaporates overnight so you can't use too much. When you finally get it where you want, a squeegee works but isn't required. I just rub it down with a folded microfiber cloth from the center towards the outside with light pressure. Never had a single bubble to work out. I have some of Terry's decals that were installed 20 years ago that still look great. None have ever turned loose! 4 3 Share this post Link to post Share on other sites
AlexR 3,013 #11 Posted May 5 I uhh put them on dry... So I just had to get it right the first time.. I forgot about that you can spray them to set them. 4 Share this post Link to post Share on other sites
SylvanLakeWH 31,569 #12 Posted May 5 34 minutes ago, AlexR said: I uhh put them on dry... So I just had to get it right the first time.. I forgot about that you can spray them to set them. Me too... 2 1 Share this post Link to post Share on other sites
kpinnc 18,521 #13 Posted May 6 (edited) 5 hours ago, SylvanLakeWH said: Me too... You guys just do stuff right the first time. I screw up a half dozen times first, then get it right. My first attempt at just about anything ends with "Well,... $hit"... Edited May 6 by kpinnc 6 Share this post Link to post Share on other sites
702854boy 820 #14 Posted May 6 8 hours ago, kpinnc said: My first attempt at just about anything ends with "Well,... $hit"... You ain't alone there, however its usually only if I'm alone 3 Share this post Link to post Share on other sites
oliver2-44 11,555 #15 Posted May 6 8 hours ago, kpinnc said: My first attempt at just about anything ends with "Well,... $hit"... Now that’s a T Shirt or Plaque for all our shops 1 3 Share this post Link to post Share on other sites
kpinnc 18,521 #16 Posted May 6 7 hours ago, 702854boy said: You ain't alone there, however its usually only if I'm alone My daughter asked me once why I talk to myself so much. I told her my grandpaw always said only take advice from the smarter folks... so I talk to the smartest fella around me at the time. 2 5 1 Share this post Link to post Share on other sites
jsp_333 291 #17 Posted May 9 I’m planning on redoing my 418-8 and was hung up over the whole “how do you get the decals on so they look right” I was planning on painting/ clear coating over the old decals to create a template. Then remove the old one put on the new ones. Anybody else tried this and how successful were you? 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,569 #18 Posted May 9 3 minutes ago, jsp_333 said: I was planning on painting/ clear coating over the old decals to create a template. Then remove the old one put on the new ones. Anybody else tried this and how successful were you? I would think you will end up with a ridge of paint built up around the new decal?... I'd remove everything, get it all smooth, and just carefully apply the new decal... 1 Share this post Link to post Share on other sites
jsp_333 291 #19 Posted May 9 18 minutes ago, SylvanLakeWH said: I would think you will end up with a ridge of paint built up around the new decal?... I'd remove everything, get it all smooth, and just carefully apply the new decal... Yeah, I’ve decided to abandon the idea. Just discovered all the sanding required after clear coating, so it really wouldn’t make much sense and would probably damage the decals. Soap and water sounds like the way to go. 1 1 Share this post Link to post Share on other sites
