Retired Wrencher
Engine swap
Retired Wrencher
Ok just asking if this can be done. I know where a K301 12 hp. But it is gear start. Can this be converted to a start /gen set up? Any thoughts are welcome.
squonk
Yes. If you want the complete Start /Gen look you will have to either remove the ring gear from the flywheel or get the correct flywheel to use the non hump shroud. Same thing with the small blocks. This 875 has an engine from a B 80
  • Excellent 2
leabassett@sbcglobal.net
If you have  old engine just use the parts off it to convert over. You may need the oil pan from it also.
953 nut
1 hour ago, Retired Wrencher said:
can be done.
Anything your pockets are deep enough to finance CAN be done, and we are here to help you spend your money!
If you have or can find a K301 that has all The S/G parts and pieces already in place that would be your best bet. If you go the full S/G route you may need to do a bit of rewiring but we can help you get it done.
  • Haha 2
ri702bill
You will need a big block style S/G .... for a couple of reasons. Brackets for the correct fitment and you need the longer body S/G.
The shorter one from a K161 7HP may not have enough "cookies" (oomph??) to get the job done.
A couple more to consider.... that is a lot of motor to spin over  - it may struggle. Also, the S/G setup is only 3 Amps.....
pfrederi
The S/G will put out 12 amps...
ri702bill
Good to know.
Retired Wrencher
I already have the K241.
Retired Wrencher
I do not care about if the charge or not I have battery maintainers to do this,
This one will have a gear starter. So that is why I asked if it is possible to do this.
953 nut
:confusion-confused:             are you saying you want to run the gear starter but have the S / G there for appearances only?
squonk
The starter and genny brackets bolt to the same 2 holes. I don't think there will be room for both, Never mind the electrical nightmare.
The 8 HP genny and big block gennies are the same size. Only that 161 gennie is short.
pfrederi
You can use some spacers to get between a long and short generator body
Retired Wrencher
Richard No I would like to convert a K301 to start/Gen set up.
Retired Wrencher
I don’t need both just need to swap it just a generator if possible.
Sparky
Just to clear up the confusion in this thread.
 He has a 1057 with a Kohler 10 start gen that he feels the motor is “all-done”.
  The Kohler 12 he is considering is gear start and he wants to eliminate that and swap over all the start gen components from his 10 to the 12.
  • Like 6
702854boy
:text-yeahthat:That makes a lot more sense
953 nut
Your belt guard, S / G and the bracket it mounts on will be a direct swap as will the flywheel cover but           :confusion-confused:       I don't think the flywheel from a k-241 will be compatible with the K-301 crank shaft due to balancing differances. Perhaps @gwest_ca or @richmondred01 can confirm this one way or the other.
richmondred01
The k241 has a different stroke then the k301. Therefore, the cranks are different and can’t be swapped.
Additionally, the flywheel for the starter generator is not set up for a stator and the bearing plates are also different because of the mounting of the stator.
The only option is the measure both flywheels and  take the ring gear off the one flywheel when it’s cherry red.
Once it’s off, heat the ring gear cherry red and drop in on the other flywheel and let cool.
Edited by richmondred01
squonk
Just remove the ring gear from the 301 flywheel. I've done 2  of them. Easy Peasy. You can slice the ring gear off with a cutting wheel.
Edited by squonk
